[mapguide-users] Saving a point to map permanently
saloua wakrim wakrimsaloua.wakrim at gmail.com
Tue Jun 9 09:21:43 EDT 2009
Skipped content of type multipart/alternative-------------- next part --------------
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
public partial class essai : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="essai.aspx.cs"
Inherits="essai" %>
<%@ Import Namespace="System" %>
<%@ Import Namespace="System.IO" %>
<%@ Import Namespace="System.Collections.Specialized" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
<%@ Import Namespace="System.Text" %>
<%@ Import Namespace="System.Globalization" %>
<%@ Import Namespace="System.Xml" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head id="Head1" runat="server">
    <title>selection</title>
</head>
<body>
    String sessionid1;
     MgSiteConnection siteConnection;
     MgResourceService resourceSrvc;
     String mapname;
     MgMap map;
         mapname = "Shboygan";
        String configPath = "C:\\Program Files\\MapGuideOpenSource\\WebServerExtensions\\www\\webconfig.ini";
        MapGuideApi.MgInitializeWebTier(configPath);
        MgSite site1 = new MgSite();
        MgUserInformation userInfo = new MgUserInformation("Administrator", "admin");
        siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        site1 = siteConnection.GetSite();
        sessionid1 = site1.CreateSession();
        userInfo.SetMgSessionId(sessionid1);
        resourceSrvc = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService) as MgResourceService;
        MgResourceIdentifier resourceID = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
        MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
        map = new MgMap(siteConnection);
        map.Create(resourceSrvc, resourceID, mapname);
        map.Save();
        map.Open(resourceSrvc, mapname);
        string myLayerName = "drawdeuxpoints";
        String wkt = map.GetMapSRS();
        MgClassDefinition bufferClass = new MgClassDefinition();
        bufferClass.SetName("BufferClass");
        MgPropertyDefinitionCollection properties = bufferClass.GetProperties();
        MgDataPropertyDefinition idProperty = new MgDataPropertyDefinition("ID");
        idProperty.SetDataType(MgPropertyType.Int32);
        idProperty.SetReadOnly(true);
        idProperty.SetNullable(false);
        idProperty.SetAutoGeneration(true);
        properties.Add(idProperty);
        MgPropertyDefinitionCollection idProperties =  bufferClass.GetIdentityProperties();
        idProperties.Add(idProperty);
        MgGeometricPropertyDefinition polygonProperty = new MgGeometricPropertyDefinition("BufferGeometry");
        polygonProperty.SetGeometryTypes(MgFeatureGeometricType.Point);
        polygonProperty.SetHasElevation(false);
        polygonProperty.SetHasMeasure(false);
        polygonProperty.SetSpatialContextAssociation("LL84");
        properties.Add(polygonProperty);
        bufferClass.SetDefaultGeometryPropertyName("BufferGeometry");
        MgDataPropertyDefinition labelProperty = new MgDataPropertyDefinition("Label");
        labelProperty.SetDataType(MgPropertyType.String);
        properties.Add(labelProperty);
        MgFeatureSchema bufferSchema = new MgFeatureSchema("BufferLayerSchema",  "temporary schema to hold a buffer");
        bufferSchema.GetClasses().Add(bufferClass);
        //String wkt = "GEOGCS["+"WGS84 Lat/Long's, Degrees, -180 ==> +180"+", DATUM["+"D_WGS_1984"+", SPHEROID["+"World_Geodetic_System_of_1984"+", 6378137, 298.257222932867]], PRIMEM["+"Greenwich"+", 0], UNIT["+"Degree"+", 0.017453292519943295]]";
        MgCreateSdfParams sdfParams = new MgCreateSdfParams("LL84", map.GetMapSRS(), bufferSchema);
        string featurePath = "Library://Samples/Sheboygan/Data/drawdeuxpoints.FeatureSource";
        MgResourceIdentifier bufferFeatureResId =  new MgResourceIdentifier(featurePath);
        featureService.CreateFeatureSource(bufferFeatureResId, sdfParams);
        /*MgPropertyCollection propertyValues = new MgPropertyCollection();
        MgPropertyCollection propertyValues2 = new MgPropertyCollection();
        MgGeometryFactory factory = new MgGeometryFactory();
        propertyValues.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(factory.CreatePoint(factory.CreateCoordinateXY(-87.704986990962839, 43.707520000480347)))));
        propertyValues2.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(factory.CreatePoint(factory.CreateCoordinateXY(-87.744986990962839, 43.747520000480347)))));
        //à revoir c koi feature source name
        propertyValues.Add(new MgStringProperty("Label", "point1"));
        propertyValues.Add(new MgStringProperty("Label", "ponit2"));*/
        MgInsertFeatures insert = new MgInsertFeatures("BufferLayerSchema:BufferClass", point1());
        MgInsertFeatures insert2 = new MgInsertFeatures("BufferLayerSchema:BufferClass", point2());
        MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
        commands.Add(insert);
        commands.Add(insert2);
        featureService.UpdateFeatures(bufferFeatureResId, commands, false);
        //LayerDefinition
        //MgResourceIdentifier templateLayerId = new MgResourceIdentifier("Library://Samples/Sheboygan/Layers/calquepoint.LayerDefinition");
        //MgByteReader oldContent = resourceService.GetResourceContent(templateLayerId);
        StreamReader sr = File.OpenText("C:\\Program Files\\MapGuideOpenSource\\WebServerExtensions\\www\\point.txt");
        String template  = sr.ReadToEnd();
        //string strXml = oldContent.ToString();
        XmlDocument document = new XmlDocument();
        document.LoadXml(template);
        XmlNode node = document.SelectSingleNode("LayerDefinition/VectorLayerDefinition/ResourceId");
        node.InnerText = featurePath;
        System.IO.MemoryStream outStream = new System.IO.MemoryStream();
        document.Save(outStream);
        byte[] newByteXml = outStream.ToArray();
        outStream.Close();
        string newStrXml = Encoding.UTF8.GetString(newByteXml);
        newByteXml = Encoding.UTF8.GetBytes(newStrXml.Substring(1));
        MgByteSource source = new MgByteSource(newByteXml, newByteXml.Length);
        MgByteReader newContent = source.GetReader();
        string layerPath = "Library://Samples/Sheboygan/Layers/drawdeuxpoints.LayerDefinition";
        MgResourceIdentifier newLayerId = new MgResourceIdentifier(layerPath);
        resourceSrvc.SetResource(newLayerId, newContent, null);
        MgLayer layer = new MgLayer(newLayerId, resourceSrvc);
        layer.SetDisplayInLegend(true);
        layer.SetLegendLabel("BufferClass");
        layer.SetName("BufferClass");
        layer.SetSelectable(true);
        layer.SetVisible(true);
        layer.ForceRefresh();
        MgLayerCollection layers = map.GetLayers();
        layers.Add(layer);
        map.Save(resourceSrvc);
        mesuredistance(map);
            //Response.Write(DoesLayerExist(myLayerName, map).ToString());
        MgByteSource content2 = new MgByteSource("C:\\Program Files\\MapGuideOpenSource\\WebServerExtensions\\www\\drawpoint\\mapdefinition.xml");
            resourceSrvc.SetResource(resourceID, content2.GetReader(), null);
 <div id="Div1">
 <iframe id="carte" width="1000" height="800" frameborder="0" scrolling="no" src="http://localhost/mapguide/mapviewerajax/?SESSION=<%=sessionid1 %>&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout" name="fenetre"></iframe>
 </div>
 <br />
 <div>
<input type="button" value="rafresh" name="digitligne" onclick="rafresh();"/>
</div>
</body>
<script type="text/javascript">
     function rafresh()
    //carte.GetMapFrame().GetLayers(true,true);
   //carte.GetScriptFrame().location.href = "essai.aspx";
   frames['fenetre'].location.reload();
    carte.GetMapFrame().Refresh();
    //carte.ExecuteMapAction(20);
    //carte.GetMapFrame().ExecuteMapAction(1);
    //carte.GetTaskFrame().location.href = "essai.aspx"
    //carte.GetMapFrame().ExecuteMapAction(20);
</script>
<script runat=server>
    MgGeometry pointa;
    MgGeometry pointb;
    Double distanceunits;
    Double distancemeters;
    Boolean DoesLayerExist(String LayerName, MgMap Map)
        MgLayerCollection layers = Map.GetLayers();
        return (layers.Contains(LayerName));
    MgPropertyCollection point1()
        //MgPropertyCollection propertyValues2 = new MgPropertyCollection();
        pointa = factory.CreatePoint(factory.CreateCoordinateXY(-87.704986990962839, 43.707520000480347));
        propertyValues.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(pointa)));
        //propertyValues2.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(factory.CreatePoint(factory.CreateCoordinateXY(-87.744986990962839, 43.747520000480347)))));
        //propertyValues.Add(new MgStringProperty("Label", "ponit2"));
        return propertyValues;
    MgPropertyCollection point2()
        MgGeometryFactory factory2 = new MgGeometryFactory();
        //propertyValues.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(factory2.CreatePoint(factory.CreateCoordinateXY(-87.704986990962839, 43.707520000480347)))));
        pointb = factory2.CreatePoint(factory2.CreateCoordinateXY(-87.744986990962839, 43.747520000480347));
        propertyValues2.Add(new MgGeometryProperty("BufferGeometry", new MgAgfReaderWriter().Write(pointb)));
        propertyValues2.Add(new MgStringProperty("Label", "point2"));
        return propertyValues2;
   public Double mesuredistance(MgMap map)
        String srs=map.GetMapSRS();
        MgCoordinateSystemMeasure mesure = new MgCoordinateSystemMeasure(srs);
        distanceunits = pointa.Distance(pointb, mesure);
        Response.Write(distanceunits.ToString());
        //distancemeters = srs.ConvertCoordinateSystemUnitsToMeters(distanceunits);
        //Response.Write(distancemeters.ToString());
        return distancemeters;
</script>
</html>
<LayerDefinition version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd">
  <VectorLayerDefinition>
    <ResourceId>%s</ResourceId>
    <FeatureName>BufferLayerSchema:BufferClass</FeatureName>
    <FeatureNameType>FeatureClass</FeatureNameType>
    <Geometry>BufferGeometry</Geometry>
    <ToolTip> </ToolTip>
    <VectorScaleRange>
      <PointTypeStyle>
                <DisplayAsText>true</DisplayAsText>
                <AllowOverpost>false</AllowOverpost>
                <PointRule>
                    <LegendLabel>point1</LegendLabel>
                    <PointSymbolization2D>
                        <Mark>
                            <Unit>Centimeters</Unit>
                            <SizeContext>DeviceUnits</SizeContext>
                            <SizeX>0.3</SizeX>
                            <SizeY>0.3</SizeY>
                            <Rotation>0</Rotation>
                            <Shape>Square</Shape>
                            <Fill>
                                <FillPattern>Solid</FillPattern>
                                <ForegroundColor>FF0000FF</ForegroundColor>
                                <BackgroundColor>FF000000</BackgroundColor>
                            </Fill>
                        </Mark>
                    </PointSymbolization2D>
                </PointRule>
            </PointTypeStyle>
    </VectorScaleRange>
  </VectorLayerDefinition>
</LayerDefinition>
