[mapguide-users] Saving a point to map permanently
saloua wakrim
wakrimsaloua.wakrim at gmail.com
Tue Jun 9 11:17:49 EDT 2009
this step is necessary just when you want that changes you are adding to map
be saved on map in mapguidestudio cause it knows just xmldef of map, else
it's not necessary, so it works now?
2009/6/9 sathishpsk9 <sathishpsk9 at gmail.com>
> Hi
> thank you very much..... i did the same with a little difference that i
> create a point features and layer defintion at runtime and added it to map
> using map.GetLayers().insert(0,myLayer);
> but i did not do the last step ........... saving map with current map
> contents...
> ThankS& Regards
> satish
> http://n2.nabble.com/Saving-a-point-to-map-permanently-tp3041754p3049824.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090609/4a3e54b0/attachment.html
