[mapguide-users] Dwg to shape
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 10 08:28:54 EDT 2009
For what it's worth - I've never found Studio (any version) able to open
a single one of my dwgs. I wouldn't recommend that - I'd go along with
the DXF suggestion...you can then use something like ArcView (or maybe
MapWindow could do it) to import the dxf and export as a shp file).
Andrew
On 6/10/2009 9:24 AM, Martin Morrison wrote:
> Correct, but you either spend countless hours trying to write a program that will be out of date with the next release, possibly infringing on copyrights, may not read all objects etc. or just buy a product (either Map or Studio) that will pay for itself...the right tool for the job.
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan Milicevic
> Sent: Wednesday, June 10, 2009 8:17 AM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Dwg to shape
> For small amount of money ;-)
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
> Morrison
> Sent: Wednesday, June 10, 2009 1:58 PM
> You can also buy AutoCAD Map will export a dwg to shape.
> Martin
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Skovhede, GEOGRAF A/S
> Sent: Wednesday, June 10, 2009 4:00 AM
> Subject: Re: [mapguide-users] Dwg to shape
> AFAIK, the DWG is a proprietary format.
> There exists an OpenDWG alliance with a DWG library,
> but calling it "open source" is incorrect in my opinion.
> It is non-trivial to understand the DWG file format,
> especially since the 2004 version came out.
> I don't think any open source projects support DWG.
> If you have access to AutoCAD or similar,
> try exporting it as DXF as that is an open format:
> http://en.wikipedia.org/wiki/AutoCAD_DXF
> Your easiest bet is to purchase MapGuide Studio which
> can read in DWG files, and store them as SDF's (I think?).
> You can then use FDOToolbox to convert them to SHP.
> However, the current license model requires you to purchase
> MGE to get a copy of Studio, so that may be too much.
> Otherwise you can look at FME Universal Translator,
> which is capable of converting just about anything:
> http://docs.safe.com/fme/html/UT/welcome_to_fme_universal_translator.htm
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> iam using mapguide opensource 2.0
>> is there are any mapguide opensource dlls for converting drawing file
> to
>> shape files and vice versa................
>> can anybody worked on this criteria......................
>> Regards,
>> Padmini.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
