[mapguide-users] Getting User domain and username active directory
from task pane
Olyster
mcnolii at hotmail.com
Wed Jun 10 11:10:32 EDT 2009
I'm new to MapGuide.
I want to retrieve active directory domain and user name from TaskPane. I
used MapGuide Studio to create a web layout and I developed a webpage
(RightPane.aspx) with Visual Web Developer to be displayed in the taskPane.
I have a header frame (containing HeaderFrame.aspx which is showing a
banner) and the MapGuide frame below.
>From the Header Frame, I can get user's active directory info using :
Dim User As System.Security.Principal.IPrincipal
User = System.Web.HttpContext.Current.User
TxtUser.Text = User.Identity.Name
Which returns the domain name and user name of the currently connected user.
But If I try to get the same info with the same code in the page.load of
RightPane.aspx, I get nothing and I can't debug the page. I have to set it
as start page to debug it.
I tried to go up to the HeaderFrame from RightPane.aspx using javascript but
I get Access denied at a certain point (different domain I guess)
So I'd like to know how I can debug a custom .aspx page which resides in the
TaskPane and/or Get active directory info from a page which resides in the
taskPane.
I hope this is clear enough.
Thanks for your help.
View this message in context: http://n2.nabble.com/Getting-User-domain-and-username-active-directory-from-task-pane-tp3056279p3056279.html
