[mapguide-users] 2.1 installation problem
Jackie Ng
jumpinjackie at gmail.com
Thu Jun 11 20:25:05 EDT 2009
This is a known issue that has been shelved for the next release.
http://trac.osgeo.org/mapguide/ticket/889
- Jackie
Andrew DeMerchant wrote:
> Maybe they should be disabled in the FDO right form the installer -
> right now, you get errors as soon as you try to edit a layer. It's not
> exactly user-friendly, right now...
> Commenting those out solved the problem, by the way. Thanks!
> Andrew
> On 6/11/2009 10:46 AM, Zac Spitzer wrote:
>> yeah, but you need the oracle client for oracle to work, same goes for
>> postgres, ie libpq.dll
>> On Thu, Jun 11, 2009 at 10:25 PM, Andrew
>> DeMerchant<andrew.demerchant at gemtec.ca> wrote:
>>> Wouldn't a default install have installed all of the fdo's? Shouldn't
>>> they
>>> all work out of the box?
>>> Andrew
>>> On 6/10/2009 11:35 PM, Zac Spitzer wrote:
>>> try commenting out the fdo providers your not using from providers.xml
>>> On Thu, Jun 11, 2009 at 5:57 AM, Andrew
>>> Oh - and OCI.dll is also missing, apparently...
>>> Andrew
>>> On 6/10/2009 4:55 PM, Andrew DeMerchant wrote:
>>> Ok - totally fresh install on Windows 2000 server...the one thing I did
>>> do
>>> was install 2.0 using IIS and then removing it and installing 2.1 on
>>> Apache.
>>> This was to replicate my existing conditions. I get an error saying that
>>> mgserver.exe is unable to locate LIBPQ.dll. I did a search on the HD and
>>> couldn't find it anywhere. This is coming up when I try to edit a data
>>> source that was created and working in 2.0. From what I've seen so far,
>>> it
>>> seems to run faster - but until I get a 100% working install, I'm stuck
>>> with
>>> 2.0...any help?
>>> Andrew
>>> On 6/2/2009 11:01 AM, Andrew DeMerchant wrote:
>>> Removing that line in php.ini did nothing for me - same error.....the
>>> dr.watson log in my event log lists the following (from when httpd
>>> crashes):
>>> "The application, , generated an application error The error occurred on
>>> 06/02/2009 @ 10:38:27.130 The exception generated was c0000005 at
>>> address
>>> 77FCD989 (RtlZeroHeap) "
>>> I don't know apache, so interactive mode isn't something that I know how
>>> to
>>> do (though I'll gladly try it with instructions). Also, this w2k
>>> installation is totally up to date with WindowsUpdate.
>>> Andrew
>>> On 6/2/2009 10:07 AM, Jackie Ng wrote:
>>> Ok I've just done a clean install on a Windows 2000 VM with a trunk
>>> build
>>> installer (roughly the same as the 2.1 beta) using Apache/PHP and I have
>>> a
>>> functioning server and web extensions.
>>> I also got the same problems with php_MapGuideApiEnvConfig.dll in my
>>> error
>>> logs.
>>> So there must be some other factor at play here.
>>> Have you tried running both the MapGuide Server and/or Apache
>>> interactively?
>>> Please note that I also installed the Windows 2000 Update Rollup package
>>> as
>>> well. I don't know if this makes a difference.
>>> - Jackie
>>> Jackie Ng wrote:
>>> Not quite, from your observations it seems the main offender is the
>>> Looking at the source-code, you'll see the GetModuleHandleEx() API I
>>> mentioned being used.
>>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
>>> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve
>>> multiple
>>> different versions of php installed on the same system.
>>> If the only version of PHP you're using is the one that comes with
>>> MapGuide, then you can remove the reference to
>>> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
>>> operational.
>>> If so, then we just need to see if a Windows 2000 equivalent API exists
>>> (GetModuleHandle???) that does the same thing.
>>> - Jackie
>>> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
>>> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
>>> dead end street for the unforeseeable future. Is that correct?
>>> Andrew
>>> James Card wrote:
>>> Aha! That explains why I was getting the same symptoms last week.
>>> Perhaps we could persuade someone to add a note to the downloads page
>>> at<http://mapguide.osgeo.org/download/releases/2.1.0>.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Andrew DeMerchant
>>> Computer Technologist
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> Andrew DeMerchant
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> E3C 2E6
>>> Andrew DeMerchant
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> E3C 2E6
>>> Andrew DeMerchant
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> E3C 2E6
> *Andrew DeMerchant*
> *Computer Technologist*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
View this message in context: http://n2.nabble.com/How-to-Save-Redline-Object-on-a-new-Layer-tp2992274p3065306.html
