[mapguide-users] King.Oracle important update
marius.360
marius at osssa.co.za
Fri Jun 12 03:51:37 EDT 2009
Aaah, that is surely what my problem is! Thanks, I will download that and
try it, silly mistake by me!
Simon Pelicon wrote:
> Hi!
> I replaced old king oracle dll's for MapGudie 2.0.2 with the new
> ones and it works without problem.
> MapGuide 2.0.2 uses FDO 3.3.1 so check if you are using the right King
> Oracle provider version for FDO 3.3.1 .
> download link:
> http://www.sl-king.com/fdooracle/download/FdoKingOracle_Win32_FDO_3_3_1_v0_8_10.zip
> Simon
> marius.360 wrote:
> I think so, my 2.0.2 installation is still standard, I have not changed
> anything except the King.Oracle DLL's?
> Marius
> Haris Kurtagic wrote:
> Are you using correct binaries, for 3.3.1 ?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [ mailto:mapguide-users-bounces at lists.osgeo.org ] On Behalf Of marius.360
> Sent: Thursday, June 11, 2009 3:35 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] King.Oracle important update
> Hi Harris,
> I have tried to get my MGOS 2.0.2 working with the latest King.Oracle
> provider, but I am having difficulties with that. It works fine with
> 2.1. I
> just replace the old DLL's with the new ones and then edit the
> providers.xml
> file to reflect the new version on the 2.0.2 setup, but it doesn't work,
> if
> I open an existing data connection in studio it is blank. Is there
> anything
> else I must do to get it working on 2.0.2? I must be doing something
> silly...
> Please pardon my ignorance, but I am a bit of a novice in this regard!
> Marius
> Yes it can. We use it with MG 2.0.2.
> When I build new version of provider I build for older versions of FDO
> too. So you can use it as far back as MapGuide 1.2 (FDO 3.2.2).
> Haris
> marius.360
> Sent: Tuesday, June 09, 2009 2:36 PM
> Subject: Re: [mapguide-users] King.Oracle important update
> Hi Haris
> This is very good news! Quick question though, can this new version be
> used
> with version 2.0.2 of mapguide?
> Thanks a lot,
> Marius
> Hi,
> I have released new version of King.Oracle provider. It solves
> stability
> issue with MapGuide and King.Oracle.
> Haris
> mapguide-users mailing list
> http://n2.nabble.com/King.Oracle-important-update-tp3048272p3049174.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://n2.nabble.com/King.Oracle-important-update-tp3048272p3061966.html
View this message in context: http://n2.nabble.com/King.Oracle-important-update-tp3048272p3066415.html
