[mapguide-users] Geting Selected Features
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jun 12 09:18:33 EDT 2009
Instead of:
Dim map as New MgMap()
try
Dim map as New MgMap(resourceService)
Regards, Kenneth Skovhede, GEOGRAF A/S
Matt Feeney skrev:
> Trying to get the Features that have been selected from a Ajax Map Viewer.
> The JavaScript is passing back the selection XML to the server side.
> On the Page Postback, i read the Params that are returned, depending on the
> correct parameter value i run the function below.
> Private Sub ListSelected(ByVal sessionId As String, ByVal mapname As String,
> ByVal selectionXML As String)
>         Dim userInfo As MgUserInformation = New MgUserInformation(sessionId)
>         Dim site As New MgSite()
>         site.Open(userInfo)
>         Dim siteConnection As New MgSiteConnection()
>         siteConnection.Open(userInfo)
>         Dim map As New MgMap()
>         Dim mapId As MgResourceIdentifier = New
> MgResourceIdentifier("Session:" + sessionId + "//" + mapname + "." +
> MgResourceType.Map)
>         Dim resourceService As MgResourceService =
> siteConnection.CreateService(MgServiceType.ResourceService)
>         map.Open(resourceService, mapname)
>         Dim featureService As MgFeatureService =
> siteConnection.CreateService(MgServiceType.FeatureService)
>         Dim sel As MgSelection = New MgSelection(map, selectionXML)
>         sel.Open(resourceService, mapname)
>         Dim lyrs As MgReadOnlyLayerCollection = sel.GetLayers()
>         For Each lyr As MgLayerBase In lyrs
>             If lyr.Selectable = True Then
>                 Dim count As Integer = sel.GetSelectedFeaturesCount(lyr,
> lyr.GetFeatureClassName())
>                 sel.GetSelectedFeatures(lyr, lyr.GetClassName(), False)
>             End If
>         Next
> End Sub
> The line of text in bold throws an exception which makes no sense. (see
> Below)
> OSGeo.MapGuide.MgNullReferenceException was unhandled by user code
>   Message="Null reference."
>   Source="MapGuideDotNetApi"
>   StackTrace:
>     - MgMap.GetService line 93 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\MapLayer/Map.cpp
> Many Thanks in Advanace
> Matt
