[mapguide-users] Map Guide Getting Started
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 15 04:54:35 EDT 2009
is the packages directory path correct in server\bin\serverconfig.ini?
On Mon, Jun 15, 2009 at 6:40 PM, mohammad abdraboh<mmuslem2002 at gmail.com> wrote:
> Dear, Spitzer
> Thank you for your reply
> You are right, I have a mgp in the server\packages directory and tried to
> import it with map admin, and the error message was
> under the (load package) section, I received (No packages found)
> Thank you
> Mohammad
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
