[mapguide-users] Map versioning
Martin Morrison
martin.morrison at edsi.com
Mon Jun 15 08:34:28 EDT 2009
As far as I know the software hasn't been written yet. You will have to write something to do this functionality. I don't think you are going to find any docs on it.
If you are just looking at a history of maps you can create different datasets and give the user a menu to switch back and forth. If you are wanting each user to see a personal revision history that is going to get very tricky in a hurry. Either way you will need to develop the code or get someone to write it for you.
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sathishpsk9
Sent: Monday, June 15, 2009 8:29 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Map versioning
Hi Martin,
I cannot find sufficient info on map versioning concept . and
i don't think i understood clearly the concept oa map versioning .........
so please send some urls or docs or code
View this message in context: http://n2.nabble.com/Map-versioning-tp3079225p3080004.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
