[mapguide-users] Enable/Disable toolbar buttons?
zolinko
zolinko at freemail.hu
Mon Jun 15 09:51:13 EDT 2009
thx sathishpsk9,
but are you sure it is good to modify the templates?
if you add business logic there, and later you upgrade your mapguide,
you need to update the relevant templates manually.
i've found an enablecommand javascript command.
it disables the button very well, but it doesn't change the style of the
button.
sathishpsk9 wrote:
> you can do it by changing code in ajaxmappane.templ ...........just change
> appropriate variable to false ......
View this message in context: http://n2.nabble.com/Enable-Disable-toolbar-buttons--tp3080034p3080339.html
