[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jun 15 12:25:22 EDT 2009
Unfortunately, this is all I get from EnumerateResourceData:
<?xml version="1.0" encoding="UTF-8" ?>
<ResourceDataList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="ResourceDataList-1.0.0.xsd" />
I get the same for a new layer, or for my existing one....
On 6/15/2009 12:13 PM, Dave Wilson wrote:
> If you use the web tier test pages you should find
> EnumerateResourceData and then GetResourceData. Enumerate should tell
> you if there is a config.xml for your resource and the get will allow
> you to download it and examine it.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Monday, June 15, 2009 8:02 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] more 2.1 problems (GDAL this time)
> My production server's running the same way with no problems....my
> data is all local and accessible. I'm seeing no access errors.
> Andrew
> On 6/15/2009 10:57 AM, Zac Spitzer wrote:
> well as local system you are restricted to what you can access
> On Mon, Jun 15, 2009 at 10:14 PM, Andrew
> DeMerchant<andrew.demerchant at gemtec.ca>  <mailto:andrew.demerchant at gemtec.ca>  wrote:
>     I thought that that was how you were supposed to do it - but I don't see any
>     files. When I press "Show all", my list stays blank. I've tried changing the
>     type (right click) - no change. If I make a brand new data connection - same
>     thing. No config.xml - nothing listed at all from "show all".
>     I know it's still a beta - it's just feeling more like an alpha right now,
>     that's all. It's just a typical problem with upgrade headaches every time a
>     new version gets put out - beta or not. I'm running this all as a default
>     install on apache. It's running as Local System.
>     Andrew
>     On 6/13/2009 9:23 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
>     The config.xml is attached as a resource file.
>     In Maestro, click the "generic editor" tab, and then click the "Show all"
>     button.
>     Note that the file may be called something else than "config.xml" (usually
>     just config).
>     Regards, Kenneth Skovhede, GEOGRAF A/S
>     Zac Spitzer skrev:
>     Andrew,
>     please remember your testing a BETA, expect some pain :)
>     are you running mapguide under a user account?
>     z
>     On Sat, Jun 13, 2009 at 5:18 AM, Andrew
>     How do I get at that config.xml? I don't see it in Maestro...that's likely
>     the problem though. I had tried to keep my alias the same, but thanks to a
>     buggy handling of mapped drives, that didn't work. I then copied things
>     locally and moved the alias....which means that the local path would be
>     different. But I have gone into Maestro and edited the path since then, to
>     use the new alias....would it not overwrite the config.xml with the new,
>     correct path?
>     andrew
>     On 6/12/2009 4:09 PM, Dave Wilson wrote:
>     When you "Upgraded" did you import a package to a new instance or did you
>     upgrade in place?
>     There is a design issue with FDO such that it doesn't know about the MG
>     aliases. The paths to the data are expanded and written into the config.xml.
>     If the path has changed then this will fail. For example if you had local
>     data under e:\data and now it's on d:\data.
>     If the path on the alias has changed this would explain why you can see the
>     data in Maestro, but unless you resave the source the config.xml might be
>     incorrect.
>     Of course if no paths have changed (note I didn't say Alias) then something
>     else is likely wrong.
>     Dave
>     From:mapguide-users-bounces at lists.osgeo.org  <mailto:mapguide-users-bounces at lists.osgeo.org>
>     [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>     DeMerchant
>     Sent: Friday, June 12, 2009 12:53 PM
>     To: MapGuide Users Mail List
>     Subject: [mapguide-users] more 2.1 problems (GDAL this time)
>     Sorry for the barrage of problems - but this seems to happen every time
>     there's an update....I've said it before, but it would be REALLY nice if the
>     upgrade process could be made without breaking everything.
>     Anyway - my problem right now is with the gdal provider. I had an air photo
>     layer and data source working fine in 2.0....after the upgrade to 2.1, that
>     died. If I edit the existing datasource, and do a preview of it, I don't see
>     any of my photos listed (the datasource points to an alias - which works,
>     because I see the files listed in Maestro). I've tried debugging using
>     CPL_DEBUG=ON, but that's not giving me any errors. I'm totally stumped as to
>     where to go from here. I also get the same problem if I make a brand new
>     datasource...
>     Andrew
>     Andrew DeMerchant
>     Computer Technologist
>     ph.1-877-2GEMTEC x.163
>     fax 506-453-9470
>     GEMTEC Limited
>     191 Doak Road
>     Fredericton, NB, Canada
>     E3C 2E6
>     ________________________________
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     Andrew DeMerchant
>     fax 506-453-9470
>     GEMTEC Limited
>     191 Doak Road
>     E3C 2E6
>     Andrew DeMerchant
>     fax 506-453-9470
>     GEMTEC Limited
>     191 Doak Road
>     E3C 2E6
> *Andrew DeMerchant*
> *Computer Technologist*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
