[mapguide-users] Modify layout with anonymous user
euskalmap
ziburudebian at free.fr
Thu Jun 18 05:01:10 EDT 2009
Sorry, I wanted to say that my c# code change the mapdefinitin in the layout
for the current session;
if i use administrator user, it seems to me that my repositories is modified
in maestro, no and i will not ?
For (Sample 1) my code is http://patxi.mayol.free.fr/ag_default3.aspx here
For (Sample 2) my xml file is http://patxi.mayol.free.fr/test_after.xml
here
Thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> You mention "layout resource", but the message states a MapDefinition is
> saved?
> Anonymous can only save to the same session, only Administrator can save
> across
> sessions.
> As for the parse error, your document is likely invalid.
> For (Sample 1), can you post the related code?
> For (Sample 2), can you post a binary copy of the document you are
> trying to save?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> I modify, by c# script, the name of the layout resource; i use the
>> MgUserInformation function with Anonymous user without password.
>> sample1 : In mapguide administrator this user have no role => so when i
>> load
>> the page i have this message :
>> Permission denied to resource:
>> Session:98d50e40-ffff-ffff-8000-0016d44491c1_en_7F0000010AFC0AFB0AFA//Map_40312.MapDefinition
>> sample 2 : if i add the role Adminstrator and Map Author of the Anonymous
>> user, i have this message :
>> An exception occurred in DB XML component. Error: XML Indexer: Fatal
>> Parse
>> error in document at line, 1, char 1. Parser message: Invalid document
>> structure
>> I understand anything ! Have you an idea ?
>> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Modify-layout-with-anonymous-user-tp3092823p3098313.html
