[mapguide-users] QUERYMAPFEATURES
Lionel Goubet lgoubet at GEOMAPGIS.com
Mon Jun 22 13:02:45 EDT 2009
Thanks you Bruce for your explanation ...
I added a ticket number #1022
For my problem, I wrote a aspx page which take a polygon and a layer name as arguments
because OPERATION=QUERYMAPFEATURES needs a layer is active.
Regards,
Lionel
Lionel GOUBET
lgoubet at geomapgis.com
Chef de projet informatique
Project Manager
GEOMAP SERVICES
Savoie Technolac
Le Square A 17 .BP 210
F-73374 Le Bourget du Lac
www.geomapgis.com
Direct :
Port.:
General :
Fax :
+33 (0) 4 79 25 38 62
+33 (0) 6 27 44 66 53
+33 (0) 4 79 25 38 80
+33 (0) 4 79 25 38 70
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Bruce Dechant
Envoyé : lundi 22 juin 2009 10:21
À : MapGuide Users Mail List
Objet : RE: [mapguide-users] QUERYMAPFEATURES
You are seeing the error because there are several "SELECTIONVARIANT" values missing from the source code. I believe the reason they are missing is that only the most common ones have been added as not all providers support all of the ones allowed by FDO.
The code that controls this is located in the HttpQueryFeatures.cpp file. Here is the code snippet of what is supported currently:
    // Create the selection variant
    INT32 selectionVariant = 0;
    if(m_selectionVariant.length() > 0)
        if (m_selectionVariant == L"TOUCHES")
            selectionVariant = MgFeatureSpatialOperations::Touches;
        else if (m_selectionVariant == L"INTERSECTS")
            selectionVariant = MgFeatureSpatialOperations::Intersects;
        else if (m_selectionVariant == L"WITHIN")
            selectionVariant = MgFeatureSpatialOperations::Within;
        else if (m_selectionVariant == L"ENVELOPEINTERSECTS")
            selectionVariant = MgFeatureSpatialOperations::EnvelopeIntersects;
        else    // add more values if necessary
            MgStringCollection arguments;
            arguments.Add(L"0");
            arguments.Add(m_selectionVariant);
            throw new MgInvalidArgumentException(L"MgHttpQueryMapFeatures.Execute",
                __LINE__, __WFILE__, &arguments, L"MgInvalidFeatureSpatialOperation", NULL);
As you can see "INSIDE" is missing - along with others.
Please create a trac ticket for this issue as the missing ones should be added. If a particular provider doesn't support the specified "SELECTIONVARIANT" then it will throw an exception and the client will know that it is a provider limitation instead of what is happening now.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of lgoubet
Sent: Friday, June 19, 2009 6:06 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] QUERYMAPFEATURES
I use
/mapguide2009/mapagent/mapagent.fcgi?OPERATION=QUERYMAPFEATURES&VERSION=1.0.0&PERSIST=1&MAPNAME=MACARTE&SESSION=e4433420-ffff-ffff-8000-005056c00001_fr_7F0000010AF20AF10AF0&SEQ=0.5438243192685027&LAYERNAMES=LAYER1&GEOMETRY=CURVEPOLYGON
((985200.554430509 111930.547565891 (CIRCULARARCSEGMENT (990200.554430509 106930.547565891, 995200.554430509 111930.547565891), CIRCULARARCSEGMENT
(990200.554430509 116930.547565891, 985200.554430509 111930.547565891))))&SELECTIONVARIANT=INTERSECTS&CLIENTAGENT=Ajax%20Viewer
and I get a response that I work with ajax/javascript.
But if I change SELECTIONVARIANT=INTERSECTS and SELECTIONVARIANT= INSIDE it doesn't work because the
Argument(s) incorrect(s): [0] = "INSIDE" L'opération spatiale de l'objet est incorrecte car elle n'est pas reconnue.
Argument(s) incorrect(s): [0] = "INSIDE" L'opération spatiale de l'objet est incorrecte car elle n'est pas reconnue. Une exception s'est produite dans la méthode MgHttpQueryMapFeatures.Execute à la ligne 115 dans le fichier d:\build\carrera_nightly\build_34.2\ent\os\web\src\httphandler\HttpQueryMapFeatures.cpp
Do you have a solution ?
Must I write a another page (aspx for me) to make this thing ?
Where find documentation on QUERYMAPFEATURES ?
Thanks you very much
View this message in context: http://n2.nabble.com/QUERYMAPFEATURES-tp3119257p3119257.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
