[mapguide-users] Bookmarking
GordonL
gordon.luckett at arrowgeomatics.com
Mon Jun 22 14:17:19 EDT 2009
Just to follow up of the Link To View error:
Webpage error details
Message: 'this.domObj.innerHTML' is null or not an object
Line: 52
Char: 9
Code: 0
URI: http://squamish2010.ca/mapguide2010/fusion/widgets/LinkToView.js
CODE:
this.anchorLabel = json.Label ? json.Label[0] : (this.domObj.innerHTML ?
this.domObj.innerHTML : 'Link to View');
GordonL wrote:
> Hi Mike,
> I have added the following to the right-click menu:
> <Item xsi:type="WidgetItemType">
> <Function>Widget</Function>
> <Widget>LinkToView</Widget>
> </Item>
> Now I get a javascript error:
> Error: 'this.domObj.nnerHTML' s not an object
> Line 2
> Char 569951
> gordon
> Mike Adair wrote:
>> Yes that looks correct for the <Widget> part, but you also need
>> something like this to add it to the toolbar:
>> <Container xsi:type="UiItemContainerType">
>> <Name>Toolbar</Name>
>> <Type>Toolbar</Type>
>> </Item>
>> There should be some way for Studio to put that in, but I'm not sure
>> how. You probably also need a label or icon for it in the <Widget>
>> element.
>> Mike
>> GordonL wrote:
>>> Thanks Mike,
>>> here is what Studio 2010 automatically puts in the xml
>>> <?xml version="1.0" encoding="utf-8"?>
>>> <WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
>>> <Name>LinkToView</Name>
>>> <Type>LinkToView</Type>
>>> <Location />
>>> <Extension />
>>> </WidgetType>
>>> does this look correct?
>>> thanks
>>> gordon
>>> I think it is a matter of adding a <Widget> entry for it and an entry in
>>> the toolbar <Container> in the AppDef.
>>> Mike
>>> GordonL wrote:
>>>> Hi Mike,
>>>> I am playing with the "Link to View" widget. What is required to add
>>>> it to the toolbar? Is there some documentation for it's use?
>>>> thanks
>>>> gordon
>>>> It does capture map extent/scale and layer state. It doesn't capture
>>>> the sessionid since that is likely to expire, it initializes the map
>>>> from the MapGuide resource ID, rather than mapname and session.
>>>> Mike
>>>> GordonL wrote:
>>>>> Hi Mike,
>>>>> Does it capture current Map Scale and Layer State?
>>>>> Also, does it cupture current SESSIONID?
>>>>> thanks
>>>>> gordon
>>>>> Mike Adair wrote:
>>>>>> Yes there is the LinkToView widget which provides bookmarking. It
>>>>>> provides a labeled anchor tag with a link to the current mapview.
>>>>>> Mike
>>>>>> Chris Claydon wrote:
>>>>>>> I think I saw some support for bookmarking go into Fusion 2.0. There
>>>>>>> are
>>>>>>> some developers from DM Solutions on this list that may be able to
>>>>>>> provide more details...
>>>>>>> -----Original Message-----
>>>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
>>>>>>> Sent: Saturday, March 14, 2009 2:56 PM
>>>>>>> To: mapguide-users at lists.osgeo.org
>>>>>>> Subject: [mapguide-users] Bookmarking
>>>>>>> Hi All,
>>>>>>> I was wondering, has anyone seen a bookmarking tool (either FUSION
>>>>>>> or
>>>>>>> Basic
>>>>>>> Web Layout)?
>>>>>>> I think there are different ways of doing this.
>>>>>>> 1. I saw one solution that grabbed the URL of the web layout
>>>>>>> (including
>>>>>>> sessionid) but this expires...
>>>>>>> 2. I thought I could capture the map name, current scale, and the
>>>>>>> current
>>>>>>> layer visibility in the session and store to a database..then apply
>>>>>>> these
>>>>>>> parameters after the user logs in.
>>>>>>> 3. I thought I saw a FUSION demo that "save map" would store the map
>>>>>>> permanently in the repository and just share it to everyone, but
>>>>>>> does
>>>>>>> anyone
>>>>>>> know if this stored the current status (scale and layer visibility
>>>>>>> status)????
>>>>>>> The issue I have with all these approaches is that this requires
>>>>>>> that the
>>>>>>> web layout is customized to accommodate the passing of these
>>>>>>> parameters...
>>>>>>> it would be great if there were URL parameters (GET or POST) that we
>>>>>>> can
>>>>>>> pass the scale and layer status to the whole Web Layout (FUSION or
>>>>>>> BASIC)...
>>>>>>> any feedback on how anyone worked through this issue would be great.
>>>>>>> thanks
>>>>>>> gordon
>>>>>> Michael Adair
>>>>>> Senior Software Architect
>>>>>> DM Solutions Group Inc.
>>>>>> Office: (613) 565-5056 x26
>>>>>> madair at dmsolutions.ca
>>>>>> http://www.dmsolutions.ca
>>>>>> http://research.dmsolutions.ca
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Michael Adair
View this message in context: http://n2.nabble.com/Bookmarking-tp2479346p3137851.html
