[mapguide-users] WMS
sathishpsk9
sathishpsk9 at gmail.com
Thu Jun 25 21:23:16 EDT 2009
HI Chris Claydon
I am Using MapGuide 2.01 , .net environment , and maestro r3911 , i
did all the set up as you said in your earlier post, when i use url 1:
http://localhost/mapguide/mapagent/mapagent.fcgi
i shows nothing in browser ..... and when use url ( Sheboygon map and bounds
as you said)
2:http://localhost/mapguide/mapagent/mapagent.fcgi?REQUEST=GetCapabilities&SERVICE=WMS&FORMAT=text/xml
i get layer information .
can you please tell me whether it is correct behaviour with url 1
and
there is any possibitiy that i can do this programmatically ?
if yes where should code such a thing ( i might be stupid , please pardon me
Thanks & Reagrds ,
satish
Chris Claydon wrote:
> I would try: http://localhost/mapguide/mapagent/mapagent.fcgi
> A simple test to see if any layers are available would be to open the
> following in a web browser, and see if you get an XML capabilities
> document back. If it works, the XML document should contain entries for
> the available layers.
> Chris.
> _____
> From: Norm Dickson [mailto:NDickson at crape.com]
> Sent: Tuesday, March 21, 2006 1:39 PM
> To: Norm Dickson; Chris Claydon; users at mapguide.osgeo.org
> Cc: Jason.Birch at nanaimo.ca
> Subject: RE: [mapguide-users] WMS
> I have all this set up now. What URL do I use to access the wms
> http://localhost/mapguide is nor returning any layers.
> Thanks
> Norm
> _____
> From: Norm Dickson
> Sent: Tuesday, March 21, 2006 12:04 PM
> To: Chris Claydon; users at mapguide.osgeo.org
> Thanks Chris. I assume this is a 1.0 feature since I do not have this
> as an option in my layers.
> I had installed 1.0 a couple of weeks ago but I found it to be slow has
> anyone else run into this?
> Norm
> _____
> <http://www.crape.com/>
> Crape Geomatics Corporation | Norm Dickson : Information Technology Lead
> | Tel: 403.514.7280 | Fax: 403.303.3784
> _____
> From: Chris Claydon [mailto:chris.claydon at autodesk.com]
> Sent: Tuesday, March 21, 2006 9:33 AM
> To: users at mapguide.osgeo.org
> WFS uses feature sources, rather than layer resources, but the
> configuration is very similar. If you open the Properties dialog for a
> feature source, the Service Properties tab contains a checkbox labeled
> "Publish via Web Feature Service". The dialog contents are slightly
> different, but the Title and Bounds fields should be configured the same
> way. I believe that setting the bounds correctly is much more important
> for WFS.
> Chris Claydon.
> _____
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Tuesday, March 21, 2006 9:25 AM
> Does this control the WFS availability as well?
> _____
> Sent: Tuesday, March 21, 2006 08:19
> Hi Norm,
> This is not yet documented. I'll try to cover as much as I can:
> The information that controls how layers are exposed via WMS is stored
> in the resource header metadata. In MapGuide Studio, if you right-click
> on a layer resource in the site explorer, select "Properties...", and
> then go to the "Service Properties" tab, you will see a checkbox labeled
> "Publish via Web Mapping Service".
> If this checkbox is checked, the layer will be exposed via WMS.
> If the "Queryable" checkbox is also checked, the layer will allow WMS
> "GetFeatureInfo" requests.
> You may wish to set the "Title" field to a user-friendly name for the
> layer. If it is left blank, it will show up in WMS using the resource
> name.
> You may also wish to set the "Bounds" value. It needs to be in a
> specific XML format. An example is given below:
> <Bounds SRS="EPSG:4326" west="-1.2345" south="-6.5432" east="10.2468"
> north="9.8765"/>
> If it is left blank, it will default in WMS to use the EPSG:4326 spatial
> reference system, which corresponds to lat/lon degrees using the WGS84
> datum, and the bounds will be set to -180, -90, 180, 90.
> In my experience with WMS client applications so far, I have not needed
> to set the bounds in order to retrieve maps and feature information
> successfully.
> I hope this information helps to get you started.
> Chris Claydon.
> _____
> Sent: Tuesday, March 21, 2006 8:13 AM
> Subject: [mapguide-users] WMS
> I feel as though I am missing something. Is there any documentation on
> exposing WMS in MGO? I can connect to the WMS service but no layers are
> exposed. Any help would be appreciated.
> Thanks,
> Norm
> _____
View this message in context: http://n2.nabble.com/WMS-tp1803379p3158823.html
