[mapguide-users] problems with maestro r3911 in fdo's
Jackie Ng jumpinjackie at gmail.com
Thu Jun 25 22:13:49 EDT 2009
Maestro isn't directly using FDO. All it is doing behind the scenes, is
relaying these requests to the MapGuide Server, which does all the heavy
lifting.
Just for a test, use the raw mapagent interface, and test the GetSchemas and
GetSpatialContext methods. Do they report the same problems?
- Jackie
T.kiran kumar reddy wrote:
> hi to everyone,
> Presently i am useing the r3911 version of the maestro for the sake of the
> map tiles (map tiling working well with this)  but previously i used
> maestro 1.0.9 with this i created some packages and data connections with
> oracle providers, now when i update maestro r3911  data (schemas and
> tables)in  oracle is not shown it gives no spatial contex found and no
> schemas found in data base when i save the data connection with oracle
> provider.. is there any special fdo providers for the maestro r3911
> presently i am useing the kingoracleprovider.dll of version 0.8.9.0 is
> there any problem with this or problem with maestro r3911 version this
> package is working good in masertro 1.0.9 with the same dll version.
> if any body knows the solution please help me.
> thanks in advance.
>  http://n2.nabble.com/file/n3158999/error.jpeg
View this message in context: http://n2.nabble.com/problems-with-maestro-r3911-in-fdo%27s-tp3158999p3159230.html
