[mapguide-users] problems with maestro r3911 in fdo's
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 26 02:56:48 EDT 2009
The warning you posted earlier was not present in Maestro 1.0.9.
It merely informs you that the FeatureSource should present a
spatial context, but did not.
Some providers work like this, eg. the ODBC provider.
I don't know about the King.Oracle one.
The error you are getting now has to do with some dll
trouble on the server.
Try opening KingOracleProvider.dll with DependencyWalker to
see what you are missing (perhaps the Oracle client?).
Regards, Kenneth Skovhede, GEOGRAF A/S
sathishpsk9 skrev:
> Hi jackie Nag
> I formatte my pc and installed
> 1.Mapguide 2.01
> 2.maestro r3911
> Mapguide by default come with oracle provider ... so i place Kingoracle dlls
> version 3.2.2 in my .../server/bin/fdo folder ...
> i even updated provider.xml with my king oracleprovider...
> i.e add following tag
> <FeatureProvider>
> <Name>OSGeo.KingOracle.3.2.2</Name>
> <DisplayName>OSGeo FDO Provider for Oracle</DisplayName>
> <Description>Read/write access to spatial and attribute data in an
> Oracle Spatial.</Description>
> <IsManaged>False</IsManaged>
> <Version>3.2.2</Version>
> <FeatureDataObjectsVersion>3.2.2</FeatureDataObjectsVersion>
> <LibraryPath>C:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
> </FeatureProvider>
> even
> i reccive following error in maestro
> The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> Unable to load the FDO Provider: The specified procedure could not be found.
> Exception occurred in method MgFdoConnectionManager.Open at line 262 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> can please help me .........
> thanks & regards
> satish kumar
