[mapguide-users] 2.1 Beta (Fusion) Problems
Benoit Begin bbegin at geomapgis.ca
Fri Jun 26 16:15:33 EDT 2009
The Firefox issue is fairly straightforward to fix, except for my lack of
understanding of the actual cause of the issue.
In ApplicationDefinition.js, the method getAppDef(xhr) needs to be changed
to be like this:
    getAppDef: function(xhr){
      if (xhr && typeof(xhr) == "object" && xhr.responseText) {
        this.sessionId = xhr.responseText;
        Fusion.sessionId = this.sessionId;
      var r = new
Fusion.Lib.MGRequest.MGGetResourceContent(this.applicationDefinition);
      r.parameters.session = this.sessionId;
      r.parameters.format = 'application/json';
      this.oBroker.dispatchRequest(r,
              OpenLayers.Function.bind(this.getAppDefCB, this));
Basically what happens is that this function is called by this line of code:
"window.setTimeout(OpenLayers.Function.bind(this.getAppDef,this),5);". For a
reason that I couldn't identify due to lack of time, the value of xhr is
sometimes equal to 5. Therefore, this causes the code to go into assigning
5.responseText (undefined) to this.sessionId and making it require to login
again.
I'm guessing it has something to do with an underlying library doing some
funky binding/prototyping under Firefox, but I didn't have time to find the
cause. My fix only works because it makes sure the xhr parameter is an
object and has the responseText parameter, so it's not really a "clean" fix
per say, but atleast it makes things work under Firefox.
Andy Morsell wrote:
> Correction, http://trac.osgeo.org/fusion/ticket/232 does not appear to be
> a
> problem in this version.
> Andy
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
> Sent: Friday, June 26, 2009 10:56 AM
> To: 'MapGuide Users Mail List'
> Subject: [mapguide-users] 2.1 Beta (Fusion) Problems
> Hi all,
> I installed MGOS 2.1 Beta yesterday and here are several Fusion problems
> that I’m seeing:
> *         Firefox is still prompting for user authentication even when
> SESSION is passed as a URL parameter.  It works ok in IE.  This has been
> mentioned in other threads here.
> *         The Secondary and Main toolbars do not appear in all MapGuide
> templates.  It looks like they may be covered by other divs.  I see this
> in
> both FF and IE.
> *         Tooltip hyperlinks do not appear as clickable hyperlinks
> anymore.
> The text of the hyperlink appears though.  Both FF and IE.
> *         Several tooltip problems that I have logged in Trac have not
> been
> fixed.  Some of these I even included the code fixes for!  These include:
> http://trac.osgeo.org/fusion/ticket/236
> http://trac.osgeo.org/fusion/ticket/237
> I will be voting -1 on releasing MGOS 2.1 until the above Fusion problems
> are fixed and a newer release of Fusion is included.  I realize that most
> of
> these problems are with Fusion, but as far as I am concerned Fusion and
> MGOS
> are intertwined in terms of functionality.  I will add the new items to
> the
> Fusion Trac in the next day or so.  My next step is to look at my ECW’s
> and
> MrSID’s with 2.1 since others have reported problems with that.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/2.1-Beta-%28Fusion%29-Problems-tp3163004p3163783.html
