[mapguide-users] creating package problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jun 29 07:00:27 EDT 2009
You should get an error message when you
start the viewer also.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> when i clicked on this map i got the error msg that
>     "<2009-06-29T15:36:01> 			Administrator
>  Error: Invalid argument(s):
>         The value cannot be less than or equal to zero.
>  StackTrace:
>   - MgRenderingServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>   - MgOpQueryFeatures.Execute line 125 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>   - MgServerRenderingService.QueryFeatures line 652 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>   - MgServerRenderingService.RenderForSelection line 1041 file
> The value cannot be less than or equal to zero."
> Regards,
> Padmini G.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> What are the messages in the error log file?
>>>   Hi,
>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1).
>>> and iam using mapguide maestro for creating packages.
>>> it works fine (loading package on ajax viewer).
>>> suddenly i got a problem from the last 2 days.the map is not showing on
>>> the
>>> browser.......
>>> http://n2.nabble.com/file/n3173532/template.jpeg
>>> i didn't get the problem.................
>>> why it happens???????????///
>>> can anybody helps me in this situation...........?
>>> Regards,
>>> Padmini G.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090629/b38cc90f/attachment.html
