[mapguide-users] 2.1 Beta (Fusion) Problems
Martin Morrison martin.morrison at edsi.com
Mon Jun 29 21:37:00 EDT 2009
Ok, I will give you that...
Martin
________________________________________
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng [jumpinjackie at gmail.com]
Sent: Monday, June 29, 2009 9:30 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 2.1 Beta (Fusion) Problems
Poor choice of 3 letter acronym :-) What I should've said is AJAX viewer is
pretty much feature complete given its design constraints (The WebLayout xml
schema)
- Jackie
Martin Morrison wrote:
> I wouldn't say Ajax is EOL...it still has a purpose.  Get Fusion as fast
> and as solid as Ajax and then you can start to think about retiring Ajax.
> Martin
> Sent: Monday, June 29, 2009 8:50 PM
> Subject: Re: [mapguide-users] 2.1 Beta (Fusion) Problems
> Agreed 100%
> Since Fusion is the way to do things now and the AJAX viewer is
> essentially
> EOL, it is imperative that we have a good out of the box user story with
> Fusion.
> I personally have not had a clean experience with previous mapguide
> releases, I always needed to patch the fusion installation straight after
> installation because of some glaring bug that slipped through the cracks.
> - Jackie
> Rock Beans wrote:
>> If MapGuide is released with yet another failed attempt at "Fusion"
>> layouts, I feel this would be the end of the road for normal everyday
>> users for a long time. I agree make sure the viewers that are
>> advertised as "included" are working before the release so everyone is
>> 100% happy.
>> On Fri, Jun 26, 2009 at 12:55 PM, Andy Morsell<amorsell at spatialgis.com>
>> wrote:
>>> Hi all,
>>> I installed MGOS 2.1 Beta yesterday and here are several Fusion problems
>>> that I’m seeing:
>>> ·         Firefox is still prompting for user authentication even when
>>> SESSION is passed as a URL parameter.  It works ok in IE.  This has been
>>> mentioned in other threads here.
>>> ·         The Secondary and Main toolbars do not appear in all MapGuide
>>> templates.  It looks like they may be covered by other divs.  I see this
>>> in
>>> both FF and IE.
>>> ·         Tooltip hyperlinks do not appear as clickable hyperlinks
>>> anymore.
>>> The text of the hyperlink appears though.  Both FF and IE.
>>> ·         Several tooltip problems that I have logged in Trac have not
>>> been
>>> fixed.  Some of these I even included the code fixes for!  These
>>> include:
>>> http://trac.osgeo.org/fusion/ticket/232
>>> http://trac.osgeo.org/fusion/ticket/236
>>> http://trac.osgeo.org/fusion/ticket/237
>>> I will be voting -1 on releasing MGOS 2.1 until the above Fusion
>>> problems
>>> are fixed and a newer release of Fusion is included.  I realize that
>>> most
>>> of
>>> these problems are with Fusion, but as far as I am concerned Fusion and
>>> MGOS
>>> are intertwined in terms of functionality.  I will add the new items to
>>> the
>>> Fusion Trac in the next day or so.  My next step is to look at my ECW’s
>>> and
>>> MrSID’s with 2.1 since others have reported problems with that.
>>> Andy Morsell, P.E.
>>> Spatial Integrators, Inc.
>>> 47° 46' N 116° 49' W
>>> www.SpatialGIS.com
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/2.1-Beta-%28Fusion%29-Problems-tp3163004p3178330.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/2.1-Beta-%28Fusion%29-Problems-tp3163004p3178470.html
