[mapguide-users] MgRenderingService RenderMap problem
Satu attila.sagi at geoview.hu
Mon Mar 2 04:19:46 EST 2009
Hi, I need a little help, in the begining...
Is this the right order to create a rendered map without a viewer?
1) Init Web API,
2) Open site,
3) Create resources: MgResourceService, MgRenderingService,
MgMappingService,
4) Set the map library to MgResourceIdentifier,
5) Create map, with MgMap,
6) ?
After these steps I have a map with 12 layers. They have a real name, and
all layers are visible.
How can I create a rendered map, with MgRenderingService?
Because, when I try, I got an empty box as rendered result, with my
background color. I don't like to use the viewer, the map need to generate
only in raster format.
(I'm using MapGuide 2009 and Visual Studio 2008.)
View this message in context: http://n2.nabble.com/MgRenderingService-RenderMap-problem-tp2384773p2408231.html
