[mapguide-users] UpdateFeatures
Zac Spitzer zac.spitzer at gmail.com
Mon Mar 2 06:06:39 EST 2009
hmm, these are both quite critical bugs IMHO...
we are talking about potential dataloss here,
should be a blocker for 2.1, I've updated the ticket for be high
http://trac.osgeo.org/mapguide/ticket/649
z
2009/3/2 Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
> Strange, i can get GetValue() but i can get name and it's "0".
> .GetItem(0).Name is "0"
> and
> GetItem(0).GetPropertyType() is "9"
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Monday, March 02, 2009 11:49 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] UpdateFeatures
> same as result.GetItem(0).GetPropertyType() ?
> z
>> Value is 9
>> Sent: Monday, March 02, 2009 11:46 AM
>> what is the value of  result.GetItem(0).GetValue() ?
>> On Mon, Mar 2, 2009 at 4:46 PM, Ivan Milicevic
>> <Ivan.Milicevic at supranet.hr> wrote:
>>> Hello Zac, hello group
>>> I'm havig the same problems as George has. Tried
>>> result.GetItem(0).GetValue() and resoult is 9. Can you help me? I'm
>>> really suffering to create this "easy to do" feature.
>>> The following code does it well, no execption, no errors but no deleted
>>> feature as well.
>>> PLease, be note that Filter string is fine.
>>> Thanx a lot.
>>>        string TIMgisUser =
>>> System.Configuration.ConfigurationManager.AppSettings["TIMgisUser"];
>>>        MapGuideApi.MgInitializeWebTier(@"C:\program
>>> files\MapguideOpenSource2.0\WebServerExtensions\www\webconfig.ini");
>>>        MgUserInformation userInfo = new
>>> MgUserInformation("Administrator", "" +
>>> System.Configuration.ConfigurationManager.AppSettings["mgP"] + "");
>>>        MgSite site = new MgSite();
>>>        site.Open(userInfo);
>>>        String mgSessionId = site.CreateSession();
>>>        MgUserInformation userInfoNew = new
>>> MgUserInformation(mgSessionId);
>>>        MgSiteConnection siteConnection = new MgSiteConnection();
>>>        siteConnection.Open(userInfoNew);
>>>        MgResourceService resourceService =
>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>> MgResourceService;
>>>        MgFeatureService featureService =
>>> siteConnection.CreateService(MgServiceType.FeatureService) as
>>> MgFeatureService;
>>>        MgResourceIdentifier resId = new
>>> MgResourceIdentifier("Library://PROJEKTI/ZLZ/PODACI/DIONICE.FeatureSourc
>>> e");
>>>        MgFeatureCommandCollection commands = new
>>> MgFeatureCommandCollection();
>>>        MgDeleteFeatures deleteCmd = new MgDeleteFeatures("DIONICE",
>>> "(FeatId='1')");
>>>        commands.Add(deleteCmd);
>>>        featureService.UpdateFeatures(resId, commands, false);
>>>        string re = featureService.UpdateFeatures(resId, commands,
>>> false).GetItem(0).GetPropertyType().ToString();
>>>        Response.Write(featureService.TestConnection(resId));
>>> Sent: Friday, August 01, 2008 3:06 AM
>>> Subject: Re: [mapguide-users] MG 1.2 vs 2.0.1
>>> yep...it does fail silently, which is really annoying.. it should just
>>> raise an exception
>>> On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
>>>> No I am not. Does this ignore the error message and process the update
>>>> somehow?
>>>> Zac Spitzer wrote:
>>>>> Are you checking the result as bellow
>>>>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>>>>> if (result.GetItem(0).GetPropertyType() eq 9)
>>>>>    result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>>>>> z
>>>>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
>>> wrote:
>>>>>> can you post some code to demonstrate the problem?
>>>>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net>
>>> wrote:
>>>>>>> Hello,
>>>>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues
>>> with
>>>>>>> adding
>>>>>>> data to feature sources discussed in this thread:
>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-wa
>>> s-busy-to16392736.html#a18556960
>>>>>>> My immediate issue is that I have a client that would really like
>>> to us
>>>>>>> FF
>>>>>>> 3.0 with my application. I see that either I need to find a way to
>>> apply
>>>>>>> the
>>>>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues
>>> with
>>>>>>> updating feature data.
>>>>>>> I could look at the code for MG 1.2 and apply the changes made to
>>> 2.0
>>>>>>> with
>>>>>>> some guidance on where to start but I think I would rather find a
>>> fix
>>>>>>> for MG
>>>>>>> 2.0.
>>>>>>> Any suggestions would be appreciated.
>>>>>>> Thanks
>>>>>>> George McLean
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
