[mapguide-users] UpdateFeatures
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 2 06:25:36 EST 2009
it's gonna take some one who knows C++ and the mapguide
code base to do this..
out of interest which provider where you using?
this should raise an exception right?
2009/3/2 Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
> So, I'll wait till 2.1 release.
> Thanks a lot, I've spend a whole weekend to solve it but without exception or error code it's impossible.
> Thank's again.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Monday, March 02, 2009 12:07 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] UpdateFeatures
> hmm, these are both quite critical bugs IMHO...
> we are talking about potential dataloss here,
> should be a blocker for 2.1, I've updated the ticket for be high
> http://trac.osgeo.org/mapguide/ticket/649
> z
>> Strange, i can get GetValue() but i can get name and it's "0".
>> .GetItem(0).Name is "0"
>> and
>> GetItem(0).GetPropertyType() is "9"
>> Sent: Monday, March 02, 2009 11:49 AM
>> same as result.GetItem(0).GetPropertyType() ?
>> z
>>> Value is 9
>>> Sent: Monday, March 02, 2009 11:46 AM
>>> what is the value of result.GetItem(0).GetValue() ?
>>> On Mon, Mar 2, 2009 at 4:46 PM, Ivan Milicevic
>>> <Ivan.Milicevic at supranet.hr> wrote:
>>>> Hello Zac, hello group
>>>> I'm havig the same problems as George has. Tried
>>>> result.GetItem(0).GetValue() and resoult is 9. Can you help me? I'm
>>>> really suffering to create this "easy to do" feature.
>>>> The following code does it well, no execption, no errors but no deleted
>>>> feature as well.
>>>> PLease, be note that Filter string is fine.
>>>> Thanx a lot.
>>>> string TIMgisUser =
>>>> System.Configuration.ConfigurationManager.AppSettings["TIMgisUser"];
>>>> MapGuideApi.MgInitializeWebTier(@"C:\program
>>>> files\MapguideOpenSource2.0\WebServerExtensions\www\webconfig.ini");
>>>> MgUserInformation userInfo = new
>>>> MgUserInformation("Administrator", "" +
>>>> System.Configuration.ConfigurationManager.AppSettings["mgP"] + "");
>>>> MgSite site = new MgSite();
>>>> site.Open(userInfo);
>>>> String mgSessionId = site.CreateSession();
>>>> MgUserInformation userInfoNew = new
>>>> MgUserInformation(mgSessionId);
>>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>>> siteConnection.Open(userInfoNew);
>>>> MgResourceService resourceService =
>>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>>> MgResourceService;
>>>> MgFeatureService featureService =
>>>> siteConnection.CreateService(MgServiceType.FeatureService) as
>>>> MgFeatureService;
>>>> MgResourceIdentifier resId = new
>>>> MgResourceIdentifier("Library://PROJEKTI/ZLZ/PODACI/DIONICE.FeatureSourc
>>>> e");
>>>> MgFeatureCommandCollection commands = new
>>>> MgFeatureCommandCollection();
>>>> MgDeleteFeatures deleteCmd = new MgDeleteFeatures("DIONICE",
>>>> "(FeatId='1')");
>>>> commands.Add(deleteCmd);
>>>> featureService.UpdateFeatures(resId, commands, false);
>>>> string re = featureService.UpdateFeatures(resId, commands,
>>>> false).GetItem(0).GetPropertyType().ToString();
>>>> Response.Write(featureService.TestConnection(resId));
>>>> Sent: Friday, August 01, 2008 3:06 AM
>>>> Subject: Re: [mapguide-users] MG 1.2 vs 2.0.1
>>>> yep...it does fail silently, which is really annoying.. it should just
>>>> raise an exception
>>>> On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
>>>>> No I am not. Does this ignore the error message and process the update
>>>>> somehow?
>>>>> Zac Spitzer wrote:
>>>>>> Are you checking the result as bellow
>>>>>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>>>>>> if (result.GetItem(0).GetPropertyType() eq 9)
>>>>>> result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>>>>>> z
>>>>>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
>>>> wrote:
>>>>>>> can you post some code to demonstrate the problem?
>>>>>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net>
>>>> wrote:
>>>>>>>> Hello,
>>>>>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues
>>>> with
>>>>>>>> adding
>>>>>>>> data to feature sources discussed in this thread:
>>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-wa
>>>> s-busy-to16392736.html#a18556960
>>>>>>>> My immediate issue is that I have a client that would really like
>>>> to us
>>>>>>>> FF
>>>>>>>> 3.0 with my application. I see that either I need to find a way to
>>>> apply
>>>>>>>> the
>>>>>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues
>>>> with
>>>>>>>> updating feature data.
>>>>>>>> I could look at the code for MG 1.2 and apply the changes made to
>>>> 2.0
>>>>>>>> with
>>>>>>>> some guidance on where to start but I think I would rather find a
>>>> fix
>>>>>>>> for MG
>>>>>>>> 2.0.
>>>>>>>> Any suggestions would be appreciated.
>>>>>>>> Thanks
>>>>>>>> George McLean
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> Zac Spitzer -
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
