[mapguide-users] Polygon are not recorded in feature
Micho Gar michogar at gmail.com
Mon Mar 2 12:43:52 EST 2009
Hi all,
I have a code that should save the polygons in the feature source after
using the Digitize. In principle I do not give any error, but when reviewing
the shp the polygon don´t appear. I leave with you the code because I don´t
see anything bad.
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resourceService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
MgFeatureService featureService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
MgResourceIdentifier zonasFeatureId = new
MgResourceIdentifier("Library://ConectorGPS/Datos/poligonosZonas.FeatureSource");
MgFeatureCommandCollection zonasComando = new MgFeatureCommandCollection();
//Abrimos el mapa
MgMap mapa = new MgMap();
mapa.Open(resourceService, mapName);
//creamos la geometria
MgGeometryFactory geometryFactory = new MgGeometryFactory();
MgCoordinateCollection coordinateCollection = new MgCoordinateCollection();
//MgLinearRingCollection interiorRingCollection = new
MgLinearRingCollection();
MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
int count = xCollection.length;
for(int i=0; i<count;i++)
    Double x = Double.valueOf(xCollection[i]);
    Double y = Double.valueOf(yCollection[i]);
    MgCoordinate  coordinate = geometryFactory.CreateCoordinateXY(x,y);
    coordinateCollection.Add(coordinate);
MgLinearRing exteriorRing =
geometryFactory.CreateLinearRing(coordinateCollection);
MgPolygon polygon = geometryFactory.CreatePolygon(exteriorRing,null);
MgByteReader geom = geometryReaderWriter.Write(polygon);
//creamos una coleccion de propiedades y la insertamos
MgPropertyCollection propiedades = new MgPropertyCollection();
propiedades.Add(new MgGeometryProperty("Geometry", geom));
propiedades.Add(new MgStringProperty("ID", "zona1"));
zonasComando.Add(new MgInsertFeatures("zonasCapa", propiedades));
featureService.UpdateFeatures(zonasFeatureId, zonasComando, false);
//capturamos la capa para salvar el mapa y refrescar
MgLayerBase zonasCapa = mapa.GetLayers().GetItem("zonasCapa");
zonasCapa.SetVisible(true);
zonasCapa.ForceRefresh();
mapa.Save(resourceService);
out.println("finish");
Thanks
# michogar
# Analista Programador SIG
# Ubuntu Linux Counter 462666
"Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
peor... Si lo reproduces del derecho... ¡Se instala!."
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
you play it right ... It installs!.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090302/7b8ad15c/attachment.html
