[mapguide-users] SQL 2008 Geographic data type can't be selected
Rodolfo Moreno
rmoreno at voxiva.com
Mon Mar 2 14:14:26 EST 2009
Thanks Andrei, I am goin to try your suggestion.
miansi wrote:
> Hello Rodolfo,
> Make sure you set SRID while populating SQL:
> , [Geo] = GEOMETRY::STGeomFromText([import].[Geo], @SRID)
> Base on your map (WGS 84) your SRID should be something like 4326
> Regards,
> Andrei
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Monday, March 02, 2009 9:15 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] SQL 2008 Geographic data type can't be
> selected
> I have could select features from geometric data type (sql 2008 as data
> source) however, for the case of geographic data type the selection of
> the
> features is not possible.
> The error shown in the log is: "sys.geometry is incompatible with
> sys.geography"
> The map that contains this layer is set as WGS 84.
> any help will be appreciated, thanks
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-t
> p2410036p2410036.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> ----Notice Regarding Confidentiality----
> This email, including any and all attachments, (this "Email") is intended
> only for the party to whom it is addressed and may contain information
> that is confidential or privileged. Sierra Systems Group Inc. and its
> affiliates accept no responsibility for any loss or damage suffered by any
> person resulting from any unauthorized use of or reliance upon this Email.
> If you are not the intended recipient, you are hereby notified that any
> dissemination, copying or other use of this Email is prohibited. Please
> notify us of the error in communication by return email and destroy all
> copies of this Email. Thank you.
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2411066.html
