[mapguide-users] Load Layer Definition XML
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Mar 3 02:42:33 EST 2009
Yes, I run it with MGE 2009.
Regards, Kenneth Skovhede, GEOGRAF A/S
clarkie342 skrev:
> Hi,
> Does MaestroAPI work with Mapguide Enterprise?
> Thanks.
> wordsy wrote:
>> Thanks for the quick response. It was exactly what I needed.
>> Cheers!
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> If you want to modify the layer xml, you just read the xml like this:
>>> MgByteReader rd = resourceSrvc.GetResource(new
>>> MgResourceIdentifier("Library://layer.LayerDefinition"));
>>> If you want to work seriously with layerdefinitions (and the MapGuide
>>> xml), I have created the MaestroAPI,
>>> which lets you manipulate classes instead of xml:
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
>>> Using the MaestroAPI, you can just do:
>>> LayerDefinition ldef =
>>> con.GetLayerDefinition("Library://layer.LayerDefinition");
>>> VectorLayerDefinition vldef = ldef.Item as VectorLayerDefinition;
>>> foreach(VectorScaleRangeType vsr in vldef.ScaleRanges)
>>> foreach(object o in vsr.Item)
>>> if (o is PointTypeStyleType)
>>> ; //Layer has points
>>> else if (o is LineTypeStyleType)
>>> ; //Layer has lines
>>> else if (o is AreaTypeStyleType)
>>> ; //Layer has polygons
>>> Also, changing a style is easy, eg:
>>> PointTypeStyleType point = vldef.ScaleRanges[0].Item[0] as
>>> PointTypeStyleType;
>>> p.PointRule[0].Label.BackgroundColor = System.Drawing.Color.Red;
>>> Then save:
>>> con.SaveResource(ldef);
>>> All is fully intellisense supported in VS.
>>> wordsy skrev:
>>>> Hey Everyone;
>>>> Fairly new to MGOS.
>>>> Here is what I am trying to do.
>>>> I have a map with many Layers. One of my requirements is to allow users
>>>> to
>>>> be able to change the layer styles via a web wizard. The user will be
>>>> able
>>>> to adjust certain styles for line/point/polygon (surface). Ie font,
>>>> symbol,
>>>> line thickness, color etc.
>>>> Already my site allows a user to select the layer they want to change,
>>>> then
>>>> change the styles for a point only. The changing doesn't seem to be a
>>>> problem right now.
>>>> The problem I have:
>>>> Once a user selects the layer they want to load. How would I get the
>>>> layer
>>>> and use XML document or XPATH or something to allow the users edit XML
>>>> nodes.
>>>> Here is my code that checks to see what layer type I have when the user
>>>> selects the layer. I have 3 different user controls (one for line, one
>>>> for
>>>> poly, one for line). What I really want, is to load the layer and
>>>> populate
>>>> the appropriate controls inside the user control.
>>>> MgSiteConnection conn = InitializeGisWebTier();
>>>> string resource = "Library://MUNICIPALITIES/" + Municipality
>>>> "/2_DATA/" + LayerName + ".FeatureSource";
>>>> MgResourceService svc =
>>>> (MgResourceService)conn.CreateService(MgServiceType.ResourceService );
>>>> // Populate some values that we will need.
>>>> MgResourceIdentifier resourceId = new
>>>> MgResourceIdentifier(resource);
>>>> MgFeatureReader featureReader =
>>>> LayerDefinitionFactory.MakeAFeatureReader(conn, resourceId);
>>>> // Find out what type of Geometric property the
>>>> FeatureSource we
>>>> uploaded has.
>>>> string geometricPropertyType =
>>>> LayerDefinitionFactory.GetFeatureSourceGeometricPropertyType(featureReader);
>>>> switch (geometricPropertyType)
>>>> case "SURFACE":
>>>> // We load the Polygon usercontrol
>>>> this.phStylizeLayerControl.Controls.Add(new
>>>> PolygonStyleBuilder());
>>>> break;
>>>> case "POINT":
>>>> // we load the point usercontrol
>>>> //this.phStylizeLayerControl.Controls.Add(new
>>>> PointStyleBuilder());
>>>> PointStyleBuilder control =
>>>> (PointStyleBuilder)LoadControl("~/Pages/Controls/PointStyleBuilder.ascx");
>>>> this.phStylizeLayerControl.Controls.Add(control);
>>>> txtSymbol.Enabled = true;
>>>> txtSymbolSize.Enabled = true;
>>>> break;
>>>> case "CURVE":
>>>> // we load the line user control
>>>> LineStyleBuilder());
>>>> break;
>>>> Thanks for any help in advance.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090303/c548b5d6/attachment.html
