[mapguide-users] Regarding - Set Feature Label at Run Time
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Mar 5 02:42:27 EST 2009
That is a bit difficult for two reasons.
1) The MapGuide style model is fairly large, so there are many subitems
to examine
2) The styles for Point, Line and Area don't share the same properties,
so they must be handled individually.
I have put up an example on how to do this here:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/IterateLayerRules
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> Hi All,
> I have to set a property as Feature Label for a layer at run time. I
> got some hints and tried with VectorLayerDefinitionType and
> TextSymbolType.But not able to do so as I don’t know the exact procedure.
> I am using maestro api for creating run time map.
> Please assist…
> I am using c#, asp.net.
> *Thanks & Regards,*
> Ravinder
> *********************************************************************************************************************************************************************%CRLF%"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is %CRLF%prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."%CRLF%*********************************************************************************************************************************************************************%CRLF%
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090305/cb5e9e44/attachment.html
