[mapguide-users] Create programmatically a map
sekko970
sekko970 at virgilio.it
Thu Mar 5 05:43:55 EST 2009
This is the result of posting:
<?xml version="1.0" encoding="UTF-8" ?>
- <ResourceList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
- <ResourceDocument>
<ResourceId>Library://MyApp/AppLayouts/MyLayout.WebLayout</ResourceId>
<Depth>3</Depth>
<Owner>Administrator</Owner>
<CreatedDate>2009-03-04T15:50:26Z</CreatedDate>
<ModifiedDate>2009-03-04T17:02:27Z</ModifiedDate>
- <ResourceDocumentHeader
xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
- <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
<Inherited>true</Inherited>
- <Groups>
- <Group>
<Name>Everyone</Name>
<Permissions>r,w</Permissions>
</Group>
</Groups>
</Security>
</ResourceDocumentHeader>
</ResourceDocument>
</ResourceList>
I also found that the error is originated if the XML has nodes like
<Function>Command</Function>; if the XML has nodes like
<Function>Separator</Function>, there aren't errors.
Fabio
Kenneth Skovhede, GEOGRAF A/S wrote:
> Have you tried posting the document to the webform?
> http://localhost/mapguide/mapagent/index.html
> Regards, Kenneth Skovhede, GEOGRAF A/S
> sekko970 skrev:
>> Dear all,
>> I just found the cause of my problem.
>> My web-layout xml template is a copy of a new layout XML structure
>> created
>> from MGMaestro:
>> <?xml version="1.0" encoding="utf-8"?>
>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>> <Title>MyMapTitle</Title>
>> <Map>
>> <ResourceId>MyMap.MapDefinition</ResourceId>
>> <HyperlinkTarget>TaskPane</HyperlinkTarget>
>> </Map>
>> <ToolBar>
>> <Visible>true</Visible>
>> <Button xsi:type="CommandItemType">
>> <Command>Print</Command>
>> </Button>
>> </ToolBar>
>> <InformationPane>
>> <Width>200</Width>
>> <LegendVisible>true</LegendVisible>
>> <PropertiesVisible>true</PropertiesVisible>
>> </InformationPane>
>> <ContextMenu>
>> <MenuItem xsi:type="CommandItemType">
>> <Command>Select</Command>
>> </MenuItem>
>> </ContextMenu>
>> <TaskPane>
>> <Width>280</Width>
>> <TaskBar>
>> <Home>
>> <Name>Home</Name>
>> <Tooltip>Return to home task page</Tooltip>
>> <Description>Return to home task page</Description>
>> <ImageURL>../stdicons/icon_home.gif</ImageURL>
>> <DisabledImageURL>../stdicons/icon_home_disabled.gif</DisabledImageURL>
>> </Home>
>> <Forward>
>> <Name>Forward</Name>
>> <Tooltip>Forward to next task page</Tooltip>
>> <Description>Forward to next task page</Description>
>> <ImageURL>../stdicons/icon_forward.gif</ImageURL>
>> <DisabledImageURL>../stdicons/icon_forward_disabled.gif</DisabledImageURL>
>> </Forward>
>> <Back>
>> <Name>Back</Name>
>> <Tooltip>Return to previous task page</Tooltip>
>> <Description>Return to previous task page</Description>
>> <ImageURL>../stdicons/icon_back.gif</ImageURL>
>> <DisabledImageURL>../stdicons/icon_back_disabled.gif</DisabledImageURL>
>> </Back>
>> <Tasks>
>> <Name>Tasks</Name>
>> <Tooltip>Task list</Tooltip>
>> <Description>View a list of available tasks</Description>
>> <ImageURL>../stdicons/icon_tasks.gif</ImageURL>
>> <DisabledImageURL>../stdicons/icon_tasks_disabled.gif</DisabledImageURL>
>> </Tasks>
>> <MenuButton xsi:type="CommandItemType">
>> <Command>Measure</Command>
>> </MenuButton>
>> </TaskBar>
>> </TaskPane>
>> <StatusBar>
>> </StatusBar>
>> <ZoomControl>
>> </ZoomControl>
>> <CommandSet>
>> <Command xsi:type="BasicCommandType">
>> <Name>Pan</Name>
>> <Label>Pan</Label>
>> <Tooltip>Pan mode</Tooltip>
>> <Description>Drag the map to view areas out of range</Description>
>> <ImageURL>../stdicons/icon_pan.gif</ImageURL>
>> <DisabledImageURL>../stdicons/icon_pan_disabled.gif</DisabledImageURL>
>> <TargetViewer>All</TargetViewer>
>> <Action>Pan</Action>
>> </Command>
>> </CommandSet>
>> </WebLayout>
>> If the XML layout definition contains a <button> node chilld of <toolbar>
>> node, or a <MenuItem> node chilld of <ContextMenu> node, or a
>> <MenuButton>
>> chilld of <TaskPane><TaskBar> node, or a <Command> node chilld of
>> <CommandSet> node, it is generated the following error:
>> The type 'OSGeo.MapGuide.MgNullArgumentException' nell'assembly
>> 'MapGuideDotNetApi, Version = 2.0.2.3011, Culture = neutral,
>> PublicKeyToken
>> = null' is not marked as serializable.
>> How can I fix it?
>> Thanks in advance.
>> Fabio
>>> There are/were problems reading data using the MgByteReader, as it would
>>> not return more than 8K.
>>> You are using the native API, which, IMO, has some quirks.
>>> Maestro uses the http interface to store the file, so that is equivalent
>>> to posting using the webform.
>>> sekko970 skrev:
>>>> The file is 21K.
>>>> I tryed also to load it directly from Maestro, and I have had no
>>>> problem.
>>>>> Just to be sure...
>>>>> The xml you posted is the ResourceHeader, and not the ResourceContent,
>>>>> so it does not really show what the problem may be.
>>>>> The error from the log states that the runtime map is not created,
>>>>> which
>>>>> is strange because a WebLayout cannot reference a runtime map.
>>>>> The other error you posted seemed to indicate that the Print command
>>>>> was
>>>>> invalid inside the WebLayout.
>>>>> Can you try so save the xml, just before you write it to the
>>>>> MgByteStream?
>>>>> Then try to post the file, using the SetResource in the webform
>>>>> mentioned earlier.
>>>>> If you get the same error, try to post the file somewhere, and provide
>>>>> a
>>>>> link.
>>>>> Be carefull not to copy/paste, but post the actual file.
>>>>> Btw. how large is the file? larger than 8K?
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2428613.html
