[mapguide-users] Create programmatically a map
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Mar 5 08:30:46 EST 2009
The output shown seems to be from EnumerateResources.
There is no output from posting the Xml in the SetResource call,
except perhaps an error message.
I would like you to try posting the document using SetResource,
and report the results.
Regards, Kenneth Skovhede, GEOGRAF A/S
sekko970 skrev:
> This is the result of posting:
> <?xml version="1.0" encoding="UTF-8" ?>
> - <ResourceList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
> - <ResourceDocument>
> <ResourceId>Library://MyApp/AppLayouts/MyLayout.WebLayout</ResourceId>
> <Depth>3</Depth>
> <Owner>Administrator</Owner>
> <CreatedDate>2009-03-04T15:50:26Z</CreatedDate>
> <ModifiedDate>2009-03-04T17:02:27Z</ModifiedDate>
> - <ResourceDocumentHeader
> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
> - <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
> <Inherited>true</Inherited>
> - <Groups>
> - <Group>
> <Name>Everyone</Name>
> <Permissions>r,w</Permissions>
> </Group>
> </Groups>
> </Security>
> </ResourceDocumentHeader>
> </ResourceDocument>
> </ResourceList>
> I also found that the error is originated if the XML has nodes like
> <Function>Command</Function>; if the XML has nodes like
> <Function>Separator</Function>, there aren't errors.
> Fabio
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Have you tried posting the document to the webform?
>> http://localhost/mapguide/mapagent/index.html
>> sekko970 skrev:
>>> Dear all,
>>> I just found the cause of my problem.
>>> My web-layout xml template is a copy of a new layout XML structure
>>> created
>>> from MGMaestro:
>>> <?xml version="1.0" encoding="utf-8"?>
>>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>>> <Title>MyMapTitle</Title>
>>> <Map>
>>> <ResourceId>MyMap.MapDefinition</ResourceId>
>>> <HyperlinkTarget>TaskPane</HyperlinkTarget>
>>> </Map>
>>> <ToolBar>
>>> <Visible>true</Visible>
>>> <Button xsi:type="CommandItemType">
>>> <Command>Print</Command>
>>> </Button>
>>> </ToolBar>
>>> <InformationPane>
>>> <Width>200</Width>
>>> <LegendVisible>true</LegendVisible>
>>> <PropertiesVisible>true</PropertiesVisible>
>>> </InformationPane>
>>> <ContextMenu>
>>> <MenuItem xsi:type="CommandItemType">
>>> <Command>Select</Command>
>>> </MenuItem>
>>> </ContextMenu>
>>> <TaskPane>
>>> <Width>280</Width>
>>> <TaskBar>
>>> <Home>
>>> <Name>Home</Name>
>>> <Tooltip>Return to home task page</Tooltip>
>>> <Description>Return to home task page</Description>
>>> <ImageURL>../stdicons/icon_home.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_home_disabled.gif</DisabledImageURL>
>>> </Home>
>>> <Forward>
>>> <Name>Forward</Name>
>>> <Tooltip>Forward to next task page</Tooltip>
>>> <Description>Forward to next task page</Description>
>>> <ImageURL>../stdicons/icon_forward.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_forward_disabled.gif</DisabledImageURL>
>>> </Forward>
>>> <Back>
>>> <Name>Back</Name>
>>> <Tooltip>Return to previous task page</Tooltip>
>>> <Description>Return to previous task page</Description>
>>> <ImageURL>../stdicons/icon_back.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_back_disabled.gif</DisabledImageURL>
>>> </Back>
>>> <Tasks>
>>> <Name>Tasks</Name>
>>> <Tooltip>Task list</Tooltip>
>>> <Description>View a list of available tasks</Description>
>>> <ImageURL>../stdicons/icon_tasks.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_tasks_disabled.gif</DisabledImageURL>
>>> </Tasks>
>>> <MenuButton xsi:type="CommandItemType">
>>> <Command>Measure</Command>
>>> </MenuButton>
>>> </TaskBar>
>>> </TaskPane>
>>> <StatusBar>
>>> </StatusBar>
>>> <ZoomControl>
>>> </ZoomControl>
>>> <CommandSet>
>>> <Command xsi:type="BasicCommandType">
>>> <Name>Pan</Name>
>>> <Label>Pan</Label>
>>> <Tooltip>Pan mode</Tooltip>
>>> <Description>Drag the map to view areas out of range</Description>
>>> <ImageURL>../stdicons/icon_pan.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_pan_disabled.gif</DisabledImageURL>
>>> <TargetViewer>All</TargetViewer>
>>> <Action>Pan</Action>
>>> </Command>
>>> </CommandSet>
>>> </WebLayout>
>>> If the XML layout definition contains a <button> node chilld of <toolbar>
>>> node, or a <MenuItem> node chilld of <ContextMenu> node, or a
>>> <MenuButton>
>>> chilld of <TaskPane><TaskBar> node, or a <Command> node chilld of
>>> <CommandSet> node, it is generated the following error:
>>> The type 'OSGeo.MapGuide.MgNullArgumentException' nell'assembly
>>> 'MapGuideDotNetApi, Version = 2.0.2.3011, Culture = neutral,
>>> PublicKeyToken
>>> = null' is not marked as serializable.
>>> How can I fix it?
>>> Thanks in advance.
>>> Fabio
>>>> There are/were problems reading data using the MgByteReader, as it would
>>>> not return more than 8K.
>>>> You are using the native API, which, IMO, has some quirks.
>>>> Maestro uses the http interface to store the file, so that is equivalent
>>>> to posting using the webform.
>>>> sekko970 skrev:
>>>>> The file is 21K.
>>>>> I tryed also to load it directly from Maestro, and I have had no
>>>>> problem.
>>>>>> Just to be sure...
>>>>>> The xml you posted is the ResourceHeader, and not the ResourceContent,
>>>>>> so it does not really show what the problem may be.
>>>>>> The error from the log states that the runtime map is not created,
>>>>>> which
>>>>>> is strange because a WebLayout cannot reference a runtime map.
>>>>>> The other error you posted seemed to indicate that the Print command
>>>>>> was
>>>>>> invalid inside the WebLayout.
>>>>>> Can you try so save the xml, just before you write it to the
>>>>>> MgByteStream?
>>>>>> Then try to post the file, using the SetResource in the webform
>>>>>> mentioned earlier.
>>>>>> If you get the same error, try to post the file somewhere, and provide
>>>>>> a
>>>>>> link.
>>>>>> Be carefull not to copy/paste, but post the actual file.
>>>>>> Btw. how large is the file? larger than 8K?
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090305/ae751580/attachment.html
