[mapguide-users] Base64 encoding decoding scenarios
Traian Stanev traian.stanev at autodesk.com
Fri Mar 6 14:09:04 EST 2009
You have to know the data type of the thing you are decoding. If it is a string, the decoded byte array is a utf8 string with a null terminator. So you have to look at it as an array of bytes, and not a number.
If I take the integer 892744497 and convert to hex using little endian, I get the bytes { 0x31, 0x33, 0x36, 0x35 }. If I look at this as an array of characters, it corresponds to { '1', '3', '6', '5'}.  Does that look familiar?
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren Medermach (External)
Sent: Friday, March 06, 2009 1:58 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Base64 encoding decoding scenarios
No ideas, comments, suggestions from anyone?  ;-)
Warren M
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren Medernach
Sent: Monday, March 02, 2009 10:43 AM
Subject: [mapguide-users] Base64 encoding decoding scenarios
I'm working on decoding the UIDs passed in the selection XML, and I want to thank the group for all of the posts on decoding base 64 as I can successfully decode a UID now!
However, when I attempt to decode a UID that is NOT made up a single integer field, I'm running into some problems:
Scenario #1:
If the UID consists of 2 integer fields, upon decoding, only the first value is returned.
Example, objects Key fields are:
     UID1: value=1684
     UID2: value=1365
When I decode this, only the first value, 1684, is returned.
Do I need to do something different for decoding a feature where there are multiple key fields?
Scenario #2
If the UID consists of a text field, the decoded value is incorrect.
Example, object UID = '1365-1684'
Decoded, the returned value is: 892744497
And I noticed if multiple objects are selected, it seems all of the decoded values are: 892744497
Any comments, ideas, suggestions would be greatly appreciated.
Warren M
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090306/3beace53/attachment.html
