[mapguide-users] MgConfigurationException when calling MgSiteConnection->Open
dorshemer dorshemer at gmail.com
Mon Mar 9 11:38:25 EDT 2009
Thanks, that seems to do the trick!
Kenneth Skovhede, GEOGRAF A/S wrote:
> It's called MgInitializeWebTier, and there is an example of it's usage
> here:
> http://mapguide.osgeo.org/files/mapguide/docs/webapi/d5/d10/class_mg_feature_service.htm
> Regards, Kenneth Skovhede, GEOGRAF A/S
> dorshemer skrev:
>> Thanks for the reply.
>> Am I suppose to use InitializeWebTier in PHP? I found no reference for
>> this
>> at all.
>> Here is my webconfig.ini. Again, this works fine on the bundled
>> installation
>> but not on IIS installation:
>> [GeneralProperties]
>> DefaultMessageLocale = en
>> ResourcesPath = C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent\Resources
>> TcpIpMtu = 1460
>> TempPath = C:\WINDOWS\Temp
>> SelectionFilterSize = 100000
>> [AdministrativeConnectionProperties]
>> Port = 2810
>> [ClientConnectionProperties]
>> Port = 2811
>> [SiteConnectionProperties]
>> IpAddress = 127.0.0.1
>> Port = 2812
>> [AgentProperties]
>> DebugPause = 0
>> DisableAuthoring = 0
>> DisableWfs = 0
>> DisableWms = 0
>> [OgcProperties]
>> WfsPassword = wfs
>> WmsPassword = wms
>> [WebApplicationProperties]
>> TemplateRootFolder = C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\templates\mapguide
>> WidgetInfoFolder = C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\widgets\widgetinfo
>> ContainerInfoFolder = C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\containerinfo
>>> I think you need to call "InitializeWebTier" at some point.
>>> If you have done so, you may be using an outdated "webconfig.ini" file.
>>> Regards,Kenneth Skovhede, GEOGRAF A/S
>>> dorshemer skrev:
>>>> Hello,
>>>> I run these commands on both a bundled configuration and an IIS one:
>>>> $sessionId = $_REQUEST['SESSION'];
>>>> $userInfo = new MgUserInformation($sessionId);
>>>> $siteConnection = new MgSiteConnection();
>>>> $siteConnection->Open($userInfo);
>>>> It works fine on the bundled server, but on IIS (configured with both
>>>> PHP
>>>> and .NET support) I get the following error:
>>>> "Failed to retrieve message for "MgConfigurationException"
>>>> I couldn't find anything helpful, so I decided to post this.
>>>> Can anyone help?
>>>> Thanks,
>>>> Dor
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/MgConfigurationException-when-calling-MgSiteConnection-%3EOpen-tp2435133p2449664.html
