[mapguide-users] Modify layout and layer on map
euskalmap ziburudebian at free.fr
Mon Mar 9 12:30:44 EDT 2009
sorry for my late reply !!
So, i do not understand where can i writing my code (remember that my code
change layout definition and filters in map layers).
mapgudie load map in /mapguide/mapvierwernet/ajaxviewer.aspx,
/mapguide/mapvierwernet/mainframe.aspx and
/mapguide/mapvierwernet/mapframe.aspx.
If I execute the code before /mapguide/mapvierwernet/ajaxviewer.aspx (like
ajaxtiledviewersample.aspx in dotnetviewersample), nothing append : the
original map and filter with no modify are loading!
If I execute after, I do not where ??
you say 'simply provide the end user with a link to your special page.In
that page, do the setup, and then redirect to the MapGuide viewer files
(Response.Redirect). '
in my special page i call /mapguide/mapvierwernet/ajaxviewer.aspx but who do
I execute the instruction Response.Redirect ?
Tanks
Francis
____________________________________________________
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you are modifying the layout, you probably want to run your code
> before starting the application.
> To do so, simply provide the end user with a link to your special page.
> In that page, do the setup, and then redirect to the MapGuide viewer
> files (Response.Redirect).
> If you want to modify the map, while running the viewer, you can either
> setup a handler for the maps "OnLoad",
> which trigger your special page, or you can put in pages through "Custom
> Actions" on the layout.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> hi,
>> I developed a program which modify layout and layer on the map.
>> I do not who can i call this program (it is an aspx file with C# code) :
>> in a file in the directory mapguide/mapviewernet and with a #include or
>> after the last instruction who lad the map in a mapguide file  ?
>> I don't no who ?
>> I will not modify mapguide file to avoid the errors at the time of new
>> the
>> version mapguide.
>> Have you an idea ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Modify-layout-and-layer-on-map-tp2268226p2450009.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090309/fa5fec90/attachment.html
