[mapguide-users] SQL 2008 Geographic data type can't be selected
Rodolfo Moreno rmoreno at voxiva.com
Mon Mar 9 12:41:16 EDT 2009
Yes, my table has primary key (as integer) and spatial index with geographic
grid.
Regards,
Dave Wilson wrote:
> Can you ensure your table has a primary key? I'm pretty sure it's
> required.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Friday, March 06, 2009 4:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] SQL 2008 Geographic data type can't be
> selected
> Hi Andrei,
> sorry for my delay.
> I have created a new sql table with geography sql type and I added two
> simple polygons.
> here is my sql script:
> insert into test1
> VALUES (1,geography::STGeomFromText('POLYGON ((0 0 ,1 0,1 1 , 0 1, 0 0
> 4326) )
> insert into test1
> VALUES (2,geography::STGeomFromText('POLYGON ((1 1 ,3 1,2 3 , 1 1 ))',
> 4326)
> Next I have displayed the features with the ajax viewer of the MGOS (I am
> using 2.0.1 version) and the result is the same.
> It means that the features are shown but these can't be selected.
> I guess that it is an issue of MGOS. have you ever had success with it?
> Regards,
> Rodolfo Moreno wrote:
>> Thanks Andrei, I am goin to try your suggestion.
>> miansi wrote:
>>> Hello Rodolfo,
>>> Make sure you set SRID while populating SQL:
>>> , [Geo] = GEOMETRY::STGeomFromText([import].[Geo], @SRID)
>>> Base on your map (WGS 84) your SRID should be something like 4326
>>> Regards,
>>> Andrei
>>> Moreno
>>> Sent: Monday, March 02, 2009 9:15 AM
>>> Subject: [mapguide-users] SQL 2008 Geographic data type can't be
>>> selected
>>> I have could select features from geometric data type (sql 2008 as data
>>> source) however, for the case of geographic data type the selection of
>>> the
>>> features is not possible.
>>> The error shown in the log is: "sys.geometry is incompatible with
>>> sys.geography"
>>> The map that contains this layer is set as WGS 84.
>>> any help will be appreciated, thanks
>>> Rodolfo Moreno
>>> CivilEng
>>> View this message in context:
>>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-t
>>> p2410036p2410036.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> ----Notice Regarding Confidentiality----
>>> This email, including any and all attachments, (this "Email") is
>>> intended
>>> only for the party to whom it is addressed and may contain information
>>> that is confidential or privileged.  Sierra Systems Group Inc. and its
>>> affiliates accept no responsibility for any loss or damage suffered by
>>> any person resulting from any unauthorized use of or reliance upon this
>>> Email.  If you are not the intended recipient, you are hereby notified
>>> that any dissemination, copying or other use of this Email is
>>> prohibited.
>>> Please notify us of the error in communication by return email and
>>> destroy all copies of this Email.  Thank you.
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2438599.html
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2450086.html
