[mapguide-users] Selecting object returns wrong primary key
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Tue Mar 10 02:58:33 EDT 2009
Do you have any data that is overlaid - polygons on top of polygons? - or it
it tessalated or lines or points?
The default lookup-buffer for the MapGuide hover-over tooltip is pretty big
(4 pixels + some coord transformation that can result in a wide search).
Are you sure the hover-over is the correct ID as this can pick up other
nearby IDs?
marius.360 wrote:
> I select an object on the map, on the mouse over it gives me the correct
> primary key, but when I open a capture form where attribute information is
> displayed, another different ID is sent through, This however, does not
> happen for all objects, only a couple of them.
> Can anyone give me suggestions as to why this happen?
> Thanks
View this message in context: http://n2.nabble.com/Selecting-object-returns-wrong-primary-key-tp2448893p2453614.html
