[mapguide-users] Modify mapdefinition in a layout
euskalmap
ziburudebian at free.fr
Thu Mar 12 05:07:18 EDT 2009
It do not run with the parameter false in the instruction UTF8Encoding utf8
= new UTF8Encoding(false);
In your link sample(
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
), it is a vb code with the mapguide maetro api; i will not change all my
code because i use c# with mapguide api; i want to undestand why it do not
run; i use the same method to change the filter in layers and it run very
well ! what's append in my code?
thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> You need to create the UTF8Encoding object with the parameter "false"
> (meaning disable BOM).
> A slightly easier way to do this:
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi
>> I provide the end user with a link to my special page (see the code1). In
>> that page i redirect to the MapGuide viewer files (Response.Redirect).
>> code1:
>> http://n2.nabble.com/file/n2462320/sample1.jpg
>> The fonction SetLayout Map modify the mapdefinition in my layout. See
>> image
>> here :
>> http://n2.nabble.com/file/n2462320/sample2.jpg
>> The problem : the layout is not modify and i have this message : An
>> exception occurred in the XML parser.
>> Have you an idea ?
>> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2466236.html
