[mapguide-users] Regarding -- Shape File Editor
Jackie Ng jumpinjackie at gmail.com
Thu Mar 12 11:00:52 EDT 2009
Schema editing for shape files is extremely restrictive. You cannot edit the
structure of an existing shape file. You can only create shape files by
applying a schema (which you can add, modify and delete to your heart's
content) but once that schema is applied, it is locked in and no more
modifications can be made.
These are not restrictions imposed by FDO Toolbox, they are imposed by the
FDO SHP provider.
- Jackie
ravinder.singh wrote:
> Hi All,
> I need to modify some of the attributes of the shape file. My
> requirement is that I want to add, modify, and delete the columns in
> shape file.
> Also I need to edit the data associated with these columns.
> I downloaded the FDO Toolbox but in this tool I am unable to edit the
> data value of any column.
> Please suggest if anybody knows any freeware or open source software
> tool.
> I am using Maestro, asp.net, c#, MGOS.
> Thanks & Regards,
> Ravinder
> *********************************************************************************************************************************************************************%CRLF%"This
> message and any attachments are solely for the intended recipient and may
> contain Birlasoft confidential or privileged information. If you are not
> the intended recipient,any disclosure,copying, use, or distribution of the
> information included in this message and any attachments is
> %CRLF%prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com) and permanently
> delete this message and any attachments. Thank
> you."%CRLF%*********************************************************************************************************************************************************************%CRLF%
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Regarding----Shape-File-Editor-tp2467448p2467838.html
