[mapguide-users] Modify mapdefinition in a layout
euskalmap ziburudebian at free.fr
Thu Mar 12 12:02:22 EDT 2009
In fact, before modification, i have
MgResourceIdentifier webLayoutId = new MgResourceIdentifier(pst_weblayout)
with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
I search the xml node for modify Mapdefinition resource and
after modification i have in instruction
webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
So, i set the resource and i have the message 'An exception occurred in the
XML parser.'
I say it is simply to migrate vb to c#, but before i want to understand.
I have use same sample who use this method on the forum; but i do not
explain where is my bug?
thanks a lot for your help
Kenneth Skovhede, GEOGRAF A/S wrote:
> It is very trivial to convert the sample to C#... in fact I just did:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
> If you just want to understand what happens, there should be a more
> verbose message in the error.log:
> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
> Also, are you certain that the pst_map is a valid map identifier, and
> that str_NewMapDefinition is a valid resource identifier?
> I'm guessing that pst_map is a string like:
> "Library://map.MapDefinition", so your str_NewMapDefinition becomes:
> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> It do not run with the parameter false in the instruction UTF8Encoding
>> utf8
>> = new UTF8Encoding(false);
>> In your link sample(
>> ), it is a vb code with the mapguide maetro api; i will not change all my
>> code because i use c# with mapguide api; i want to undestand why it do
>> not
>> run; i use the same method to change the filter in layers and it run very
>> well ! what's append in my code?
>> thanks
>>> You need to create the UTF8Encoding object with the parameter "false"
>>> (meaning disable BOM).
>>> A slightly easier way to do this:
>>> euskalmap skrev:
>>>> Hi
>>>> I provide the end user with a link to my special page (see the code1).
>>>> In
>>>> that page i redirect to the MapGuide viewer files (Response.Redirect).
>>>> code1:
>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>> The fonction SetLayout Map modify the mapdefinition in my layout. See
>>>> image
>>>> here :
>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>> The problem : the layout is not modify and i have this message : An
>>>> exception occurred in the XML parser.
>>>> Have you an idea ?
>>>> Thanks
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2468271.html
