[mapguide-users] Modify mapdefinition in a layout
euskalmap
ziburudebian at free.fr
Fri Mar 13 11:38:12 EDT 2009
Yes, i have see the log file, but there is no more information that 'XML
Parser error'.
The logfile is :
http://n2.nabble.com/file/n2474100/logfile.jpg
About the XML file, after modification i have this file :
http://patxi.mayol.free.fr/mytest.xml http://patxi.mayol.free.fr/mytest.xml
Thanks
regards
Kenneth Skovhede, GEOGRAF A/S wrote:
> Did you look in the error.log file?
> Could you try to save the xml document after modification, and send a
> link to it?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> In fact, before modification, i have
>> MgResourceIdentifier webLayoutId = new
>> MgResourceIdentifier(pst_weblayout)
>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>> I search the xml node for modify Mapdefinition resource and
>> after modification i have in instruction
>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>> with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>> So, i set the resource and i have the message 'An exception occurred in
>> the
>> XML parser.'
>> I say it is simply to migrate vb to c#, but before i want to understand.
>> I have use same sample who use this method on the forum; but i do not
>> explain where is my bug?
>> thanks a lot for your help
>>> It is very trivial to convert the sample to C#... in fact I just did:
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>> If you just want to understand what happens, there should be a more
>>> verbose message in the error.log:
>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>> Also, are you certain that the pst_map is a valid map identifier, and
>>> that str_NewMapDefinition is a valid resource identifier?
>>> I'm guessing that pst_map is a string like:
>>> "Library://map.MapDefinition", so your str_NewMapDefinition becomes:
>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>> euskalmap skrev:
>>>> Hi,
>>>> It do not run with the parameter false in the instruction UTF8Encoding
>>>> utf8
>>>> = new UTF8Encoding(false);
>>>> In your link sample(
>>>> ), it is a vb code with the mapguide maetro api; i will not change all
>>>> my
>>>> code because i use c# with mapguide api; i want to undestand why it do
>>>> not
>>>> run; i use the same method to change the filter in layers and it run
>>>> very
>>>> well ! what's append in my code?
>>>> thanks
>>>>> You need to create the UTF8Encoding object with the parameter "false"
>>>>> (meaning disable BOM).
>>>>> A slightly easier way to do this:
>>>>> euskalmap skrev:
>>>>>> Hi
>>>>>> I provide the end user with a link to my special page (see the
>>>>>> code1).
>>>>>> In
>>>>>> that page i redirect to the MapGuide viewer files
>>>>>> (Response.Redirect).
>>>>>> code1:
>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>> The fonction SetLayout Map modify the mapdefinition in my layout. See
>>>>>> image
>>>>>> here :
>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>> The problem : the layout is not modify and i have this message : An
>>>>>> exception occurred in the XML parser.
>>>>>> Have you an idea ?
>>>>>> Thanks
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2474100.html
