[mapguide-users] Help: Cartographic Symbol Definition
Sherwin Luna sherwin.luna at gmail.com
Sun Mar 15 22:32:26 EDT 2009
Hi Brian,
My bad. It work. I change the background from white to black. the linetype
reflected in  my map. When I return the backgroud color from black to white
the line type still reflect. Thnks a lot.
Regards,
Sherwin
On Mon, Mar 16, 2009 at 10:25 AM, Sherwin Luna <sherwin.luna at gmail.com>wrote:
> still the same. nothing happens
> On Thu, Mar 12, 2009 at 4:37 AM, Berdel, Brian <brian.berdel at mcmtrans.com>wrote:
>> Try setting your color to 000000 and see if it shows up...I am dealing
>> with the same issue right now.  When I change the LineColor to anything but
>> black it doesn't show.  Obviously this is not a fix, I just want to see if
>> you are experiencing the same thing.
>> Thanks,
>> Brian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] On Behalf Of SCLuna
>> Sent: Monday, March 02, 2009 11:44 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Help: Cartographic Symbol Definition
>>  Good Day,
>> I was wondering if anyone could help me about cartographic symbol
>> definition. What happed was after I load the layerdefinition and look at
>> my
>> layer in edit mode in mapguide studio 2009, I can see my symbol definition
>> in the composite preview under the style area of mapguide studio 2009 but
>> when I look at my layer in preview mode the layer definition did't appear.
>> Below is what I did. I would really appreciate anyones help.
>> Below image shows what is happening in my studio 2009.
>> http://n2.nabble.com/file/n2413465/img.jpg
>> 1. I create a symbol definition in mapguide studio then save it.
>> <?xml version="1.0" encoding="UTF-8"?>
>> <SimpleSymbolDefinition version="1.0.0"
>> xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <Name>myline</Name>
>> <Graphics>
>> <Path>
>> <Geometry>
>> M 0.0,0 L 10.0,0
>> M 12.5,0 L 12.5,0
>> M 15.0,0 L 20.0,0
>> M 22.5,0 L 22.5,0
>> </Geometry>
>> <LineColor>FF0000FF</LineColor>
>> <LineWeight>0.75</LineWeight>
>> </Path>
>> </Graphics>
>> <LineUsage>
>> <VertexControl>'OverlapWrap'</VertexControl>
>> <Repeat>25</Repeat>
>> </LineUsage>
>> <ParameterDefinition/>
>> </SimpleSymbolDefinition>
>> 2. I load my new layer definition in mapguide enterprise
>> <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="LayerDefinition-1.2.0.xsd" version="1.2.0">
>> <VectorLayerDefinition>
>> <ResourceId>Library://cartographic_sample/data/line.FeatureSource</ResourceId>
>> <FeatureName>Schema1:line</FeatureName>
>> <FeatureNameType>FeatureClass</FeatureNameType>
>> <Geometry>Geom</Geometry>
>> <VectorScaleRange>
>> <CompositeTypeStyle>
>> <CompositeRule>
>> <LegendLabel>line</LegendLabel>
>> <CompositeSymbolization>
>> <SymbolInstance>
>> <ResourceId>Library://cartographic_sample/symbol/symboldefinition.SymbolDefinition</ResourceId>
>> <ParameterOverrides />
>> </SymbolInstance>
>> </CompositeSymbolization>
>> </CompositeRule>
>> </CompositeTypeStyle>
>> </VectorScaleRange>
>> </VectorLayerDefinition>
>> </LayerDefinition>
>> Thank you and Regards,
>> Sherwin
>> View this message in context:
>> http://n2.nabble.com/Help%3A-Cartographic-Symbol-Definition-tp2413465p2413465.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090316/ae37c805/attachment.html
