[mapguide-users] use WMS feature source to create layer definition
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Mar 16 03:58:30 EDT 2009
Feel free to log this as a defect for Maestro.
I'm guessing that it is a problem with coordinate systems not matching up.
You can look in the error.log for MapGuide to see if this is what happens.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> Hi Kenneth
> Thanks for these precisions.
> I have always a problem to view the WMS in the MapGuide viewer.
> With Maestro, the "preview item" of the layer (it is the same for the
> map and the layout) doesn't show the WMS. But if I use MGOS Web Studio
> to analyze the layer, the preview tool displays the WMS (it doesn't
> work with the map and the layout).
> Thanks,
> Arnaud De Groof
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* jeudi 12 mars 2009 13:29
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] use WMS feature source to create layer
> definition
> After you select the FeatureSource, you should see two comboboxes
> below the selected ResourceID.
> These are left blank, due to the bug you mentioned.
> Simply click the combobox and select the only entry avalible.
> Repeat for the combobox below.
> You can now save the layer.
> To publish a layer as a WMS entry, right click the FeatureSource and
> select properties.
> Then fill out the "WMS" tab, and remember to check the "Publish" checkbox.
> Then click OK, and the layer should appear as a WMS layer when issuing
> a GetCapabilities request.
> Hi Kenneth,
> Could you explain me in more details the procedure aiming to select
> manually the schema and column?
> In addition (for WMS server), is it possible to publish a layer (SDF
> or SHP feature resource) like a WMS with Maestro?
> Thanks,
> Arnaud De Groof
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* mercredi 11 mars 2009 18:36
> definition
> Hi Arnaud.
> That is a bug in Maestro.
> I have committed a fix for it, so it will be in the next release.
> If you manually select the Schema and Column, you should be able to save,
> and perhaps use the layer.
> The cryptic message means that you have forgotten to fill out those
> two fields :).
> Hi,
> I created a MapGuide WMS feature source according to the "FdoWmsNotes"
> (http://trac.osgeo.org/fdo/wiki/FdoWmsNotes). My first WMS feature
> corresponded to the example given in this note (NASA WMS).
> I created with success the feature resource (see picture).
> After all steps described in the note, I used MapGuide Maestro (1.0.9)
> to create layer definition.
> But when I selected the feature resource in a new layer, I received
> the following message :
> /'Failed to read schema from data source. The operation gave the error
> message : Value cannot be null. Parameter name: input.' /
> And when I saved the layer, I encountered the following exception:
> /"System.Exception: The remote server returned an error: (559)
> MgDbXmlException.: /
> /An exception occurred in DB XML component./
> /Error: XML Indexer:  Parse error in document at line, 22, char 25.
> Parser message: Element 'GridScaleRange' is not valid for content
> model:
> '(ResourceId,Opacity,(FeatureName,Geometry,Filter,GridScaleRange),ExtendedData1)'/
> /Exception occurred in method MgResourceDefinitionManager.PutDocument
> at line 554 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp"/
>  ---> System.Net.WebException: The remote server returned an error:
> (559) MgDbXmlException.
>    at System.Net.HttpWebRequest.GetResponse()
>    at
> OSGeo.MapGuide.MaestroAPI.HttpServerConnection.SetResourceXmlData(String
> resourceid, Stream content, Stream header)
>    --- End of inner exception stack trace ---
>    at
>    at
> OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.SetResourceXmlData(String
> resourceid, Stream stream)
>    at
> OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.SaveResourceAs(Object
> resource, String resourceid)
>    at OSGeo.MapGuide.Maestro.EditorInterface.Save(String resid)
> I tried also with others WMS services but I have always the same errors.
> Thanks,
> Arnaud De Groof
> ** size=2 width="100%" align=center> **
> **E-MAIL DISCLAIMER**
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> E-MAIL DISCLAIMER*
Skipped content of type multipart/related
