[mapguide-users] use WMS feature source to create layer definition
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Mar 17 06:24:14 EDT 2009
No, I have no idea why it does not always work.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> Kenneth,
> There is no error in the error.log with the example using the Nasa
> WMS. Unfortunately, the WMS isn't always displayed. Have you an idea
> of the problem?
> I tried an other WMS (http://www2.demis.nl/mapserver/Request.asp?) and
> the error.log gives the following information:
> /<2009-03-17T10:27:14> Ajax Viewer 127.0.0.1
> Administrator/
> / Error: Failed to stylize layer: wms/
> / An exception occurred in FDO component./
> / The spatial context 'EPSG:4326' is not supported by the layer
> 'Countries'. /
> / StackTrace:/
> / - MgMappingUtil.StylizeLayers line 786 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
> /An exception occurred in FDO component./
> /The spatial context 'EPSG:4326' is not supported by the layer
> 'Countries'./
> I don't understand the error because the /GetCapabilities/ of the
> Demis WMS indicates that the layer "Countries" supports the EPSG:4326 ?
> /<Layer>/
> /<Title>Demis World Map</Title>/
> /<SRS>EPSG:4326</SRS>/
> /<LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>/
> /<BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180"
> maxy="90"/>/
> /<Layer queryable="1" opaque="0">/
> /<Name>Countries</Name>/
> /<Title>Countries</Title>/
> maxy="85"/>/
> /<ScaleHint min="0" max="14000"/>/
> /</Layer>/
> Thanks,
> Arnaud De Groof
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* lundi 16 mars 2009 8:59
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] use WMS feature source to create layer
> definition
> Feel free to log this as a defect for Maestro.
> I'm guessing that it is a problem with coordinate systems not matching up.
> You can look in the error.log for MapGuide to see if this is what happens.
> Hi Kenneth
> Thanks for these precisions.
> I have always a problem to view the WMS in the MapGuide viewer.
> With Maestro, the "preview item" of the layer (it is the same for the
> map and the layout) doesn't show the WMS. But if I use MGOS Web Studio
> to analyze the layer, the preview tool displays the WMS (it doesn't
> work with the map and the layout).
> Thanks,
> Arnaud De Groof
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* jeudi 12 mars 2009 13:29
> definition
> After you select the FeatureSource, you should see two comboboxes
> below the selected ResourceID.
> These are left blank, due to the bug you mentioned.
> Simply click the combobox and select the only entry avalible.
> Repeat for the combobox below.
> You can now save the layer.
> To publish a layer as a WMS entry, right click the FeatureSource and
> select properties.
> Then fill out the "WMS" tab, and remember to check the "Publish" checkbox.
> Then click OK, and the layer should appear as a WMS layer when issuing
> a GetCapabilities request.
> Hi Kenneth,
> Could you explain me in more details the procedure aiming to select
> manually the schema and column?
> In addition (for WMS server), is it possible to publish a layer (SDF
> or SHP feature resource) like a WMS with Maestro?
> Thanks,
> Arnaud De Groof
> *Sent:* mercredi 11 mars 2009 18:36
> definition
> Hi Arnaud.
> That is a bug in Maestro.
> I have committed a fix for it, so it will be in the next release.
> If you manually select the Schema and Column, you should be able to save,
> and perhaps use the layer.
> The cryptic message means that you have forgotten to fill out those
> two fields :).
> Hi,
> I created a MapGuide WMS feature source according to the "FdoWmsNotes"
> (http://trac.osgeo.org/fdo/wiki/FdoWmsNotes). My first WMS feature
> corresponded to the example given in this note (NASA WMS).
> I created with success the feature resource (see picture).
> After all steps described in the note, I used MapGuide Maestro (1.0.9)
> to create layer definition.
> But when I selected the feature resource in a new layer, I received
> the following message :
> /'Failed to read schema from data source. The operation gave the error
> message : Value cannot be null. Parameter name: input.' /
> And when I saved the layer, I encountered the following exception:
> /"System.Exception: The remote server returned an error: (559)
> MgDbXmlException.: /
> /An exception occurred in DB XML component./
> /Error: XML Indexer: Parse error in document at line, 22, char 25.
> Parser message: Element 'GridScaleRange' is not valid for content
> model:
> '(ResourceId,Opacity,(FeatureName,Geometry,Filter,GridScaleRange),ExtendedData1)'/
> /Exception occurred in method MgResourceDefinitionManager.PutDocument
> at line 554 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp"/
> ---> System.Net.WebException: The remote server returned an error:
> (559) MgDbXmlException.
> at System.Net.HttpWebRequest.GetResponse()
> at
> OSGeo.MapGuide.MaestroAPI.HttpServerConnection.SetResourceXmlData(String
> resourceid, Stream content, Stream header)
> --- End of inner exception stack trace ---
> at
> at
> OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.SetResourceXmlData(String
> resourceid, Stream stream)
> at
> OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.SaveResourceAs(Object
> resource, String resourceid)
> at OSGeo.MapGuide.Maestro.EditorInterface.Save(String resid)
> I tried also with others WMS services but I have always the same errors.
> Thanks,
> Arnaud De Groof
> E-MAIL DISCLAIMER*
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Skipped content of type multipart/related
