[mapguide-users] Modify mapdefinition in a layout
euskalmap ziburudebian at free.fr
Tue Mar 17 06:59:16 EDT 2009
I have not send the good link of my file; in the previous version , i have
trying to delete in the xml the string
"xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd".
So, my file is :  http://patxi.mayol.free.fr/Untitled1.xml
So i test GetResourceContent rather than SetResource :
If i try  http://localhost/mapguide/mapagent/index.html
http://localhost/mapguide/mapagent/index.html  with GetResourceContent on
"Library://Ag Base/Mpg Urbanisme.WebLayout" and submit, i have this result :
http://n2.nabble.com/file/n2490672/test.jpg
The message in header, in french, is in english : This file XML does not
seem to have of information of style associated with him. The tree of the
document is shown below.
SO
Kenneth Skovhede, GEOGRAF A/S wrote:
> A bit tricky, something to do with how .Net handles Xml I think.
> The document is missing the attribute:
> Which is required, because it is used for versioning and validation.
> If you take your document and open this page:
> Then click "Resource" -> "SetResource", point out the file,
> and in the "ResourceID" field type: "Library://mytest.WebLayout".
> Then set the "Content" field to point to the file and click submit.
> You will see the error you mention.
> Now add the above attribute, so the second line in the document becomes:
> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
> Save the document, click back in the browser, and then "Submit" once more.
> This time it works. (Remember to check that the ResourceID and Content
> field has not been reset).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> Yes, i have see the log file, but there is no more information that 'XML
>> Parser error'.
>> The logfile is :
>> http://n2.nabble.com/file/n2474100/logfile.jpg
>> About the XML file, after modification i have this file :
>> http://patxi.mayol.free.fr/mytest.xml
>> Thanks
>> regards
>>> Did you look in the error.log file?
>>> Could you try to save the xml document after modification, and send a
>>> link to it?
>>> euskalmap skrev:
>>>> Hi,
>>>> In fact, before modification, i have
>>>> MgResourceIdentifier webLayoutId = new
>>>> MgResourceIdentifier(pst_weblayout)
>>>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>>>> I search the xml node for modify Mapdefinition resource and
>>>> after modification i have in instruction
>>>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>>>> with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>>>> So, i set the resource and i have the message 'An exception occurred in
>>>> the
>>>> XML parser.'
>>>> I say it is simply to migrate vb to c#, but before i want to
>>>> understand.
>>>> I have use same sample who use this method on the forum; but i do not
>>>> explain where is my bug?
>>>> thanks a lot for your help
>>>>> It is very trivial to convert the sample to C#... in fact I just did:
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>>>> If you just want to understand what happens, there should be a more
>>>>> verbose message in the error.log:
>>>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>>>> Also, are you certain that the pst_map is a valid map identifier, and
>>>>> that str_NewMapDefinition is a valid resource identifier?
>>>>> I'm guessing that pst_map is a string like:
>>>>> "Library://map.MapDefinition", so your str_NewMapDefinition becomes:
>>>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>>>> euskalmap skrev:
>>>>>> Hi,
>>>>>> It do not run with the parameter false in the instruction
>>>>>> UTF8Encoding
>>>>>> utf8
>>>>>> = new UTF8Encoding(false);
>>>>>> In your link sample(
>>>>>> ), it is a vb code with the mapguide maetro api; i will not change
>>>>>> all
>>>>>> my
>>>>>> code because i use c# with mapguide api; i want to undestand why it
>>>>>> do
>>>>>> not
>>>>>> run; i use the same method to change the filter in layers and it run
>>>>>> very
>>>>>> well ! what's append in my code?
>>>>>> thanks
>>>>>>> You need to create the UTF8Encoding object with the parameter
>>>>>>> "false"
>>>>>>> (meaning disable BOM).
>>>>>>> A slightly easier way to do this:
>>>>>>> euskalmap skrev:
>>>>>>>> Hi
>>>>>>>> I provide the end user with a link to my special page (see the
>>>>>>>> code1).
>>>>>>>> In
>>>>>>>> that page i redirect to the MapGuide viewer files
>>>>>>>> (Response.Redirect).
>>>>>>>> code1:
>>>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>>>> The fonction SetLayout Map modify the mapdefinition in my layout.
>>>>>>>> See
>>>>>>>> image
>>>>>>>> here :
>>>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>>>> The problem : the layout is not modify and i have this message : An
>>>>>>>> exception occurred in the XML parser.
>>>>>>>> Have you an idea ?
>>>>>>>> Thanks
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2490672.html
