[mapguide-users] Unable to connect to MGOS via MapGuideStudio/.NET API
Rui Daniro ruidaniro at hotmail.co.uk
Tue Mar 17 08:16:48 EDT 2009
Nothing at all, the only stuff that I have recorded there was the successful
logs, the last one was before the weekend.
De: Ivan Milicevic (via Nabble)
[mailto:ml-user+75048-116490859 at n2.nabble.com]
Enviada: 17 March 2009 12:10
Para: Rui Daniro
Assunto: RE: [mapguide-users] Unable to connect to MGOS via
Anything in mapguide error.log?
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=0>
[mailto:mapguide-users-bounces at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=1> ] On
Behalf Of Rui Daniro
Sent: Tuesday, March 17, 2009 12:57 PM
To: mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=2>
Subject: Re: [mapguide-users] Unable to connect to MGOS via
Hi all,
I am having the same problem, I left the MGOS server (version
2.0.2.3011)
idle for a while(like overnight) and then try to connect to server via
Maestro, I get the sames messages, the only difference is that I am
using
apache instead IIS. I tried to restart apache and nothing changed.
prbabu wrote:
> I am not sure either. What I did is not allow the worker process to
> recycle within IIS, even when idle and also created a separate
application
> pool for mapguide itself. This morning, I am able to login/see the map
> without any re-starts. Would not conclude this as the solution yet -
needs
> more investigation.
> Thanks for your response, though.
> Regards,
> Praveen
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> That look really odd.
>> What happens is that Maestro connects to
>> http://localhost/mapguide
>> but this is really mapped to
>> http://localhost/mapguide/mapagent/mapagent.fcgi
>> There is some logic inside Maestro (line 1027 in
>> HttpServerConnection.cs),
>> that maps from the short form to the long form.
>> If the short form fails, the long form is attempted.
>> If the long form fails, the exception for the short for is thrown,
>> which is likely what happens here.
>> I have no idea why an IIS restart would fix connection problems with
>> MapGuide.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Praveen Rajendra Babu skrev:
>>> Hi,
>>>     If I leave the MGOS server (version 2.0.2.3011) idle for a
>>> while(like overnight) and then try to connect to server via Maestro,
I
>>> get the message.
>>> ************************* Maestro pop-up window message
>>> Maestro
>>> Failed to log on because: Failed to connect, please check network
>>> connection and login information.
>>> Extended error info: Failed to connect, perhaps session is expired?
>>> Extended error info: Invalid server token recieved:
<html><head><META
>>> http-equiv="Content-Type" content="text/html;
>>> charset=UTF-8"><title>osenlighten -
>>> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
>>> <pre> / [To Parent Directory] <br><br>    Monday, December
>>> 22, 2008  3:25 PM        <dir>   HREF="/mapguide/data/">data
<br>
>>> Monday, December 22, 2008  3:32
>>> PM        <dir>
>>> HREF="/mapguide/dotnetviewersample/">dotnetviewersample <br>
>>> Tuesday, January 20, 2009 12:02 PM        <dir>
>>> HREF="/mapguide/fusion/">fusion <br>    Tuesday, January 20, 2009
>>> 11:54 AM      1847872
>>> HREF="/mapguide/fusion-1.1.0.zip">fusion-1.1.0.zip <br>   Thursday,
>>> January 08, 2009  9:46 AM        <dir>
>>> HREF="/mapguide/fusion-old/">fusion-old <br>    Monday, December
>>> HREF="/mapguide/localized/">localized <br>    Monday, December 22,
>>> 2008  3:25 PM        <dir>
HREF="/mapguide/mapadmin/">mapadmin
>>> 2008  3:25 PM        <dir>
HREF="/mapguide/mapagent/">mapagent
>>> <br>  Wednesday, January 21,
>>> 2009  6:08 PM        <dir>
>>> HREF="/mapguide/mapviewernet/">mapviewernet <br>   Tuesday,
>>> December 23, 2008 12:24 PM        <dir>
>>> HREF="/mapguide/mapviewerphp/">mapviewerphp <br>    Monday,
>>> December 22, 2008  3:25 PM        <dir>
>>> HREF="/mapguide/nad/">nad <br>     Friday, January 30, 2009  2:31
>>> PM        <dir>
HREF="/mapguide/OpenLayers-2.7/">OpenLayers-2.7
>>> <br>     Friday,
>>> January 30, 2009  1:52 PM        <dir>
>>> HREF="/mapguide/phpviewersample/">phpviewersample <br>    Monday,
>>> HREF="/mapguide/schemareport/">schemareport <br>    Monday,
>>> HREF="/mapguide/stdicons/">stdicons <br>    Monday, December 22,
>>> 2008  3:25 PM        <dir>
>>> HREF="/mapguide/viewerfiles/">viewerfiles <br>    Monday, December
>>> 22, 2008  3:27 PM         8245
>>> HREF="/mapguide/webconfig.ini">webconfig.ini <br>    Monday,
>>> HREF="/mapguide/webstudio/">webstudio <br></pre><hr></body></html>
>>> OK
>>> If I try to connect to the MGOS server via .NET API code, I get the
>>> below message:
>>> <html>
>>> <head>
>>> <title>MgConnectionFailedException</title>
>>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>>> </head>
>>> <body>
>>> <h2>Cannot establish connection.</h2>
>>> Exception occurred in method MgServerConnection.Open at line 106 in
>>> file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidec
ommon\Services/ServerConnection.cpp
>>> </body>
>>> </html>
>>>    To get things back to normal, I re-start WWW services in Windows
>>> Server 2003. Am I missing something in the set-up or configuration
of
>>> MGOS or IIS Server?  FYKI, we are using IIS Server v6.0.
>>> Any comments/suggestions would be highly appreciated.
>>> Thanks and regards,
>>> Praveen
>>> mapguide-users mailing list
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=3>
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=4>
View this message in context:
http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-
API-tp2476671p2490925.html
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=5>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2490986&i=6>
  _____
This email is a reply to your post @
http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-
tp2476671p2490986.html
You can reply by email or by visting the link above.
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.15/2004 - Release Date: 03/17/09
07:23:00
View this message in context: http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-tp2476671p2491019.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090317/fb8e4244/attachment.html
