[mapguide-users] ResizeBox
Jamo
adam.jamison at portbris.com.au
Tue Mar 17 20:47:31 EDT 2009
Thanks Traian
I have adjusted the layers xml and the symbol is now the size I desire :)
I have read through the Resize box schema
I'm a little sketchy on how the resize box functions.
If I have two paths one smaller than the other with the larger one having
AddToResizeBox
and the smaller one having AdjustToResizeBox would the smaller path then be
scaled to fit the extents of the larger one?
And how do the size paramaters fit in to this? once the second path has been
scaled to fit the extents of the first would the whole symbol then be scaled
to fit the resizebox?
Perhaps a diagram would better explain it's function ? or perhaps I just
can't get my head around it :(
Traian Stanev wrote:
> Hi,
> I checked with one of the developers of the resize box, and here is his
> answer:
> The ResizeBox functionality is not designed to do what he wants ("scale
> the symbol and make it fit to the ResizeBox").
> Here's the description from the schema's ResizeBox element:
> The optional box used to resize and reposition select graphic elements.
> The graphical extent of all elements with ResizeControl set to
> AddToResizeBox will be added to this box, potentially causing it to grow
> in size. Any change in size causes all elements with ResizeControl set to
> AdjustToResizeBox to be proportionally resized and repositioned.
> If you want to scale the whole symbol, you can use the scaling elements
> available in the SymbolInstance which references the SymbolDefinition in
> your LayerDefinition.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo
> Sent: Sunday, March 15, 2009 10:07 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] ResizeBox
> I cannot seem to get the syntax right for the resizebox control...
> I would basically like to scale the symbol and make it fit to the
> ResizeBox
> <?xml version="1.0" encoding="UTF-8"?>
> <SimpleSymbolDefinition
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="SymbolDefinition-1.1.0.xsd"
> version="1.1.0">
> <Name>House</Name>
> <Graphics>
> <Path>
> <ResizeControl>'AdjustToResizeBox'</ResizeControl>
> <Geometry>
> M 0.407,-1.604 L -0.268,-1.766 L -0.307,0.122 L -0.638, 0.086 L
> 0.711,1.686
> L 2,0.371 L 1.711,0.34 L 1.67,-1.301 L 1.177,-1.419 L 1.177,0.282 L
> 0.407,0.199 Z
> M -0.477,0.738 L -0.808,0.808 L -0.808,1.411 L -0.477,1.411 Z
> M -0.42,0.726 L -0.42,1.41 L -0.16,1.41 L -0.16,0.961 Z
> </Geometry>
> <FillColor>%FillColor2%</FillColor>
> <LineColor>%LineColor%</LineColor>
> <LineWeight>0.0</LineWeight>
> </Path>
> <Path>
> <Geometry>
> M -0.268,-1.766 L -1.636,-1.081 L -1.739,0.421 L -0.638,0.086 L
> -0.307,0.122 Z
> M -0.638,0.086 L -2,0.5 L -0.662,1.766 L 0.711,1.686 Z
> M 1.177,-1.419 L 0.407,-1.064 L 0.407,0.199 L 1.177,0.282 Z
> </Geometry>
> <FillColor>%FillColor1%</FillColor>
> </Path>
> </Graphics>
> <ResizeBox>
> <SizeX>6</SizeX>
> <SizeY>5</SizeY>
> <PositionX>0</PositionX>
> <PositionY>0</PositionY>
> <GrowControl>'GrowInXY'</GrowControl>
> </ResizeBox>
> <PointUsage>
> <Angle>%Rot%</Angle>
> </PointUsage>
> <ParameterDefinition>
> <Parameter>
> <Identifier>Rot</Identifier>
> <DefaultValue/>
> <DisplayName>Rotation</DisplayName>
> <Description>Point Symbol Rotation</Description>
> <DataType>String</DataType>
> </Parameter>
> <Parameter>
> <Identifier>FillColor1</Identifier>
> <DefaultValue/>
> <DisplayName>Fill Color 1</DisplayName>
> <Description>The Fill Color</Description>
> </Parameter>
> <Parameter>
> <Identifier>FillColor2</Identifier>
> <DefaultValue/>
> <DisplayName>Fill Color 2</DisplayName>
> </Parameter>
> <Parameter>
> <Identifier>LineColor</Identifier>
> <DefaultValue/>
> <DisplayName>Line Color</DisplayName>
> <Description>The Line Color</Description>
> </Parameter>
> <Parameter>
> <Identifier>Label</Identifier>
> <DefaultValue/>
> <DisplayName>Label</DisplayName>
> <Description>The Label Text</Description>
> </Parameter>
> </ParameterDefinition>
> </SimpleSymbolDefinition>
> http://n2.nabble.com/ResizeBox-tp2483804p2483804.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/ResizeBox-tp2483804p2494755.html
