[mapguide-users] Modify mapdefinition in a layout
euskalmap
ziburudebian at free.fr
Thu Mar 26 11:44:13 EDT 2009
Hi alucas,
you have very luck because it seems that i have problem in my C# code or perhaps in my configuration of mapguide server.
Hi
I provide the end user with a link to my special page (see the code1). In that page i redirect to the MapGuide viewer files (Response.Redirect).
code1:
The fonction SetLayout Map modify the mapdefinition in my layout. See image here :
The problem : the layout is not modify and i have this message : An exception occurred in the XML parser.
Have you an idea ?
Thanks
Hello,
this code works well for me (PHP):
function changeWebLayout($rs, $WebLayoutResId, $newMapResId, $s)
try
// Obtenemos el contenido del WebLayout en XML
$byteReader = $rs->GetResourceContent($WebLayoutResId);
$xml = $byteReader->ToString();
$doc = DOMDocument::loadXML($xml);
// Accedemos al nodo que queremos
$wl = $doc->getElementsByTagName("ResourceId");
$mapResIdNode = $wl->item(0);
$mapResIdNode->nodeValue = $newMapResId->ToString();
$strXML = $doc->saveXML();
//header('content-type: text/xml');
$byteSource = new MgByteSource($strXML, strlen($strXML));
$byteSource->SetMimeType(MgMimeType::Xml);
// Modificamos el repositorio
$rs->SetResource($WebLayoutResId, $byteSource->GetReader(), null);
catch (MgException $e)
echo $e->GetDetails();
View this message in context: http://n2.nabble.com/Modify-mapdefinition-in-a-layout-tp2462320p2539187.html
