[mapguide-users] FDO Gdal raster problem
Jsm enriquev at consortech.com
Sat Mar 28 11:42:42 EDT 2009
Ok well I let it run all night here is the final result attached.
It would be nice if you could provide how to use it as I have access to a few machines I could run it against my server.
summary-raster.xls
While I am working on this MG/raster problems, I tried to use jmeter but
problem was session.
Jason, pointed me to the Grinder http://grinder.sourceforge.net/
It was new for me and I spend couple of days around it but eventually I
was able to write Jython scripts and execute MG request as I wanted.
For example to randomize MAP image access.
Jason promised (almost) that he will blog about it, counting on it :)
He could also show some scripts we used in testing MG.
When you have you script running, it is very easy to setup to work on
many machines or use many threads to simulate concurrent users.
Perhaps Grinder could be good tool for us to run speed and stability
tests against MG.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jsm
Sent: Saturday, March 28, 2009 7:50 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] FDO Gdal raster problem
Ok found the problem,
Here are the new numbers for now, I will let Jmeter run for a few hours
and send more results.
summary-raster.xls
On Sat, Mar 28, 2009 at 4:42 PM, Jsm <enriquev at consortech.com> wrote:
> Well in the jmx file it is set to continue on error, but when you mean
profile are we talking about the same thing ? (jmx file)
yep thats what i meant
> On another note I saw this in my event viewer (jmeter on winxp, server
is on another machine win2k3):
> TCP/IP Has Reached the Security Limit Imposed on the Number of
Concurrent TCP Connect Attempts
> So it's probably my WinXP that is messing with me, I'll try and patch
my system and post Jmeter results again.
out of interested where you using localhost or your hostname
hehe, don't you just love MS :)
mapguide runs soo lot better on linux, it's just a pig to build...
z
> you don't have stop on error set in your jmeter profile?
> On Sat, Mar 28, 2009 at 4:07 PM, Jsm <enriquev at consortech.com> wrote:
>> Yes
>> There's an xls file with the stats, before and after. And also the
jmx file I used, I don't know how to use Jmeter much doh, I don't
understand why at somepoint it stops even when I choose loop forever,
but I know it's not mapguide, as I can still access it.
>> summary-old-raster.xls
>> Summary+Report.jmx
>> View this message in context:
http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548100.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548158.html
Zac Spitzer -
+61 405 847 168
http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548261.html
View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2549469.html
