[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri May 1 02:25:48 EDT 2009
My method would be to retrieve the WKT of  the buffer object,
then iterate all the layers, and for each layer execute a query with the
filter set to:
"<geometry column name> INTERSECTS GEOMFROMTEXT('...wkt...')"
You should then get all objects that are within the buffer zone.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks for ur  reply
> 1)can u plz tell me how to retrieve features with in the buffer
> area(actually im a little bit confused)
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> It looks correct, it seems to follow the edges as expected.
>> When creating the buffer, a simple method is to take each line, and
>> buffer it,
>> so it gets rounded corners.
>> Then alle the resulting buffer items are combined into a single object
>> that is the buffer.
>> If I look at your image, that seems to happen correctly.
>> The long side at the bottom right seems to be reflected in the buffer
>> edge.
>> If you would like it to be a perfect circle, you should only buffer a
>> point,
>> not a polygon.
>>> Hi Kenneth,
>>>   i have created a buffer with 0.2 miles but i think the buffer is not
>>> creating accurately
>>>      http://n2.nabble.com/file/n2745746/buffer.jpeg
>>> 1) can u provide any solution?????????????
>>> 2)And can u plz tell me the code for retrieving parcel_id with in the
>>> buffer
>>> area(im a little bit confused)
>>> plzzzzzzzz
>>> Regards,
>>> Padmini.
>>>> It looks correct to me. Try using a smaller buffer to better determine
>>>> accuracy.
>>>> For the second question, you have already asked that in another thread.
>>>> The AJAX viewer shows selection data, so try looking at the
>>>> selection.aspx files,
>>>> and see how it works.
>>>>> Hi  Kenneth,
>>>>> Thanku very much for ur help.............
>>>>> i did the coordinate system override as per ur instructions.
>>>>> It works fine
>>>>> but i felt that the buffer feature is not coming accurately??
>>>>> what was the problem????????????????????????????
>>>>> i mean by observing closely  its not an accurate circle(buffer layer).
>>>>> http://n2.nabble.com/file/n2683455/pic.jpeg
>>>>> 2)secondly i want to retrieve the parcel_ids that are included or
>>>>> intersected in the buffer layer.How  is it possible ? can u send me the
>>>>> sample code?????????
>>>>> Thanks in advance.
>>>>> Regards,
>>>>> Padmini.
>>>>>> Thats because the Sheboygan data uses a true georeferenced coordinate
>>>>>> system,
>>>>>> and your data is using a non-georeferenced system, like XY-M.
>>>>>> Arbitrary should be understood as "non-georeferenced".
>>>>>> If your data is not in the same projection as the map, you cannot use
>>>>>> the buffer feature.
>>>>>> This then returns to my initial statement: "Coordinate System
>>>>>> Override",
>>>>>> which can
>>>>>> set the data coordinate system to match the maps.
>>>>>> Can you please report what happened with with the suggestions I made,
>>>>>> regarding the coordinate system overrides?
>>>>>>> Hi,
>>>>>>> In my data
>>>>>>>     bool arbitraryMapSrs = (srsMap.GetType() ==
>>>>>>> MgCoordinateSystemType.Arbitrary);
>>>>>>> arbitraryMapSrs comes as true but in sheboygan data it comes as false
>>>>>>>         if (arbitraryMapSrs)
>>>>>>>             mapSrsUnits = srsMap.GetUnits();
>>>>>>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes
>>>>>>> as
>>>>>>> null
>>>>>>> so that
>>>>>>>  if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>>>>>>> (dsSrsUnits
>>>>>>> != mapSrsUnits)))
>>>>>>>                 excludedLayers++;
>>>>>>>                 continue;
>>>>>>> In my data  excludedLayers comes as 1 and where as in sheboyan data
>>>>>>> this
>>>>>>> condition fails....................
>>>>>>> Can u plz provide me the solution?????????????
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>>>> Why do you mention packages?
>>>>>>>> excludedLayers is incremented because the data coordinate system is
>>>>>>>> not
>>>>>>>> the same as the map coodinate system.
>>>>>>>> Please comment on what happend when you attempted my previous
>>>>>>>> suggestions.
>>>>>>>>> Hi Kenneth,
>>>>>>>>> Thanks for ur suggestions.
>>>>>>>>> I have created a package using OGR provider but in the buffering i
>>>>>>>>> found
>>>>>>>>> some problem that
>>>>>>>>>      // exclude layer if:
>>>>>>>>>             //  the map is non-arbitrary and the layer is arbitrary
>>>>>>>>> or
>>>>>>>>> vice-versa
>>>>>>>>>             //     or
>>>>>>>>>             //  layer and map are both arbitrary but have different
>>>>>>>>> units
>>>>>>>>> (arbitraryDsSrs
>>>>>>>>> (dsSrsUnits != mapSrsUnits)))
>>>>>>>>>                 excludedLayers++;
>>>>>>>>>                 continue;
>>>>>>>>> it gives difference to my data and sheboygan sample data
>>>>>>>>> so that in my code  excludedLayers is incremented to 1 so i didnt
>>>>>>>>> get
>>>>>>>>> the
>>>>>>>>> buffer features
>>>>>>>>> can u plz tell me the solution?????????????????
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>>>> I'm not sure that provider is case insensitive.
>>>>>>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>>>>>>> Also, try creating a folder, and place the files in the folder.
>>>>>>>>>> Then try to use the "External files" and point to the folder.
>>>>>>>>>> Also try pointing directly to the file.
>>>>>>>>>> When the "Test connection" is successfull, try clicking the
>>>>>>>>>> rightmost button in the "coordinate system override" field, and
>>>>>>>>>> it will show you what the provider returns as the coordinate
>>>>>>>>>> system.
>>>>>>>>>> Alternatively, try using the OGR provider instead of the SHP
>>>>>>>>>> provider.
>>>>>>>>>>> Hi Keneneth,
>>>>>>>>>>> First of all thanks for ur patience
>>>>>>>>>>> i have uploaded all the files but i didnt get the coordinate
>>>>>>>>>>> system
>>>>>>>>>>>     http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>>>>>>> again i did anything wrong??????????
>>>>>>>>>>> Regards,
>>>>>>>>>>> Padmini.
>>>>>>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>>>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>>>>>>>>> even if the upload file dialog is misleading (you must select
>>>>>>>>>>>> "All
>>>>>>>>>>>> files" to see them).
>>>>>>>>>>>> A ticket for this problem is here.
>>>>>>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>>>>>>> my code as same as previous
>>>>>>>>>>>>>  MgResourceIdentifier featSourceId = new
>>>>>>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>>>>>>>             MgSpatialContextReader ctxs =
>>>>>>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>>>>>>>             String srsDefDs = "";
>>>>>>>>>>>>>             if (ctxs != null && ctxs.ReadNext())
>>>>>>>>>>>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>>>>>>> in  srsDefDs i got null
>>>>>>>>>>>>> does i did any thing wrong
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so
>>>>>>>>>>>>>> you
>>>>>>>>>>>>>> have
>>>>>>>>>>>>>> to specify it manually.
>>>>>>>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> thanks but is it necessary overriding a coordinate
>>>>>>>>>>>>>>> system????????
>>>>>>>>>>>>>>> How it willbe done???????
>>>>>>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>>>>>>> i have seen ur link but no data available in that for
>>>>>>>>>>>>>>> overrides
>>>>>>>>>>>>>>> coordinate
>>>>>>>>>>>>>>> system
>>>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>> No, I meant "Coordinate System Override", which is located
>>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>>>>>>> See screenshots here:
>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>>>>>>> iam using maestro and i have selected  the coordinate
>>>>>>>>>>>>>>>>> system
>>>>>>>>>>>>>>>>> as
>>>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS
>>>>>>>>>>>>>>>>>>> 5.1)
>>>>>>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data
>>>>>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>>> data
>>>>>>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees,
>>>>>>>>>>>>>>>>>>> -180
>>>>>>>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>>>>>>>   srsDefDs comes as null
>>>>>>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090501/51ec8a07/attachment.html
