[mapguide-users] URL activated for feature
Andy Morsell amorsell at spatialgis.com
Mon May 4 13:01:51 EDT 2009
I have fixed this problem on my Fusion installation in the past.  You have
to edit C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\widgets\Maptip.js
.  While one would think that you could change the behavior by editing the
sWinFeatures on or around line 59, for some reason the window that is opened
does not obey these parameters.  You can manually fix it by editing the
openLink function to read something like the following:
openLink : function(evt, url) {
	//below line added since window.open did not seem to obey changes in
sWinFeatures
	var myWinFeatures =
'menubar=no,location=no,resizable=no,status=no,width=1024,height=800,scrollb
ars=yes';
        	var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
        	if ( taskPaneTarget ) {
            	taskPaneTarget.setContent(url);
        	} else {
            	var pageElement = $(this.sTarget);
            	if ( pageElement ) {
                	pageElement.src = url;
            	} else {
                		window.open(url, this.sTarget,
myWinFeatures);
        OpenLayers.Event.stop(evt, true);
        return false;
I have added two new tickets to the Fusion Trac about this bug.  They are
here:
http://trac.osgeo.org/fusion/ticket/253
http://trac.osgeo.org/fusion/ticket/254
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of achectl
Sent: Monday, May 04, 2009 1:59 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] URL activated for feature
Hi All
I found that the URL activated pop-up windows do not have scroll-bar! How
can I enable this feature? Firefox is my testing browser.
Thanks in advance. :confused:
Archectl
View this message in context:
http://n2.nabble.com/URL-activated-for-feature-tp2786234p2786234.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
