[mapguide-users] Filter Error
padmini godavarthi
godavarthi.padmini at gmail.com
Wed May 6 11:16:24 EDT 2009
Thank u very much for ur reply
can u send me the url path for updated SL-King
Page........................................
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I can confirm that using the updated provider from the
> SL-King page makes the IN operator work as expected.
> Thanks.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Kenneth Skovhede, GEOGRAF A/S skrev:
>> I was using the one that was included with FDO 3.3.2,
>> I will try with a newer version at some point.
>> Haris Kurtagic skrev:
>>> Which version of provider are using ?
>>> I remember that bug but it was solved sometime ago.
>>> I just tried with Fdo2Fdo and set Filter with IN and it works fine.
>>> Haris
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>> godavarthi
>>> Sent: Tuesday, May 05, 2009 10:44 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] Filter Error
>>> Hi, iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) Now my
>>> problem is "In" operator is not working in Setfilter option
>>> My code is as follows..................................
>>> Dim queryoptions As MgFeatureQueryOptions = New
>>> MgFeatureQueryOptions()
>>> queryoptions.AddFeatureProperty("LINK_ID")
>>> queryoptions.SetFilter("LINK_ID IN (170,143,150)") Dim
>>> increment1 As Double = IIf((5 > 1), 1.0 / (5 - 1), 1.0) Dim
>>> str As String = layer.GetFeatureClassName()
>>> Dim dataReader1 As MgFeatureReader =
>>> featureService.SelectFeatures(resId, layer.GetFeatureClassName(),
>>> queryoptions) While dataReader1.ReadNext() value
>>> = GetFeaturePropertyValue(dataReader1, "LINK_ID")
>>> filterText = """ + "LINK_ID" + "" = " filterText =
>>> filterText + value areaRuleXML =
>>> String.Format(areaRuleTemplate, "LINK_ID" +
>>> value, filterText, InterpolateColor(portion, "00FF00", "00FF00", 0),
>>> InterpolateColor(portion, "00FF00", "00FF00", 0)) areaDoc
>>> = New XmlDocument() areaDoc.LoadXml(areaRuleXML)
>>> areaNode = doc.ImportNode(areaDoc.DocumentElement, True)
>>> areaTypeStyle.AppendChild(areaNode) portion =
>>> portion + increment1 End While dataReader1.Close()
>>> It gives me the following error
>>> queryoptions) as
>>> An exception occurred in FDO component. ORA-00907: missing right
>>> parenthesis
>>> In this case Link ID is integer values not a string
>>> value......................................
>>> can u plz tell me the solution
>>> i have also tried as
>>> queryoptions.SetFilter("LINK_ID IN ({170},{143},{150})") but it gave
>>> me
>>> the error as "not a valid filter"
>>> Can anyone plz tell me the solution???????????????????/
>>> plzzzzzzzzzzzzzzzz
>>> Regards, Padmini.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Filter-Error-tp2791694p2817899.html
