[mapguide-users] Problem loading raster (TIF) files --- solved!
psciga
scigalla at battefeld.com
Thu May 7 07:41:05 EDT 2009
Jason,
thanks for your hint. Do you mean something like this?
<Feature name="3711-s">
<Band name="RGB" number="1">
<Image frame="1" name="3711-s.tif">
<Bounds>
<MinX>2536990.000</MinX>
<MinY>5710990.000</MinY>
<MaxX>2538010.020</MaxX>
<MaxY>5711509.980</MaxY>
</Bounds>
<Georeference>
<InsertionPointX>2536990</InsertionPointX>
<InsertionPointY>5710990</InsertionPointY>
<ResolutionX>0.04233326416269</ResolutionX>
<ResolutionY>0.042333306195591</ResolutionY>
<RotationX>0</RotationX>
<RotationY>0</RotationY>
</Georeference>
</Image>
</Band>
</Feature>
I ask it, because this code runs, but without any better performance.
Regards - Peter
Jason Birch wrote:
> Peter,
> If you're generating the config file based on the (outdated?) schema in
> the FDO source, you'll not get the most efficient use of the images.
> There is also a <Bounds> element (or something like that). Try generating
> a config file from Maestro for an example.
> Jason
> -----Original Message-----
> From: psciga
> Sent: April-22-09 12:29 AM
> Subject: Re: [mapguide-users] Problem loading raster (TIF) files ---
> solved!
> Please have a look on the position lines of my first posting in this
> thread.
> <InsertionPointX>2526500.000</InsertionPointX>
> <InsertionPointX>5718000.000</InsertionPointX>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2827484.html
